USB Split
Old Aug 29, 2009 | 08:31 PM
NYSH-AWD's Avatar
USB Split
Has anyone tried splitting the USB port in order to connect multiple devices? If so, does the car pick up all devices? I'm thinking of doing that so that I can connect my iPod and have an iPhone charging or a flash drive.
Old Sep 1, 2009 | 02:40 AM
bmode's Avatar
Interesting, I'm curious myself if that can be split? USB is rather flimsy with power, I doubt if the split worked, you could use it to power something substantial. Please report back if you beat me to it.
Old Sep 2, 2009 | 10:41 PM
bw5556's Avatar
headed out to give it a try now...
Old Sep 2, 2009 | 11:10 PM
bw5556's Avatar
FAIL
Old Sep 3, 2009 | 12:54 PM
jzacuto's Avatar
Denied.
Old Sep 4, 2009 | 05:13 AM
bmode's Avatar
Interesting. A great idea though, I just don't think there's enough power to run anything else if the drivers didn't shut down the connection.
Old Sep 4, 2009 | 11:34 AM
timmahh's Avatar
it's me, Alan Rickman.
The system is designed to handle one USB path/device; ie. If you plug in your ipod and a flash drive, then push the HDD/AUX button and it tries to activate USB, it wouldn't know what device to activate.. Thus giving you that error (which is kind of entertaining, please dont plug this device in again........ever!)
What devices were you trying to hook up?
Old Sep 4, 2009 | 03:56 PM
bw5556's Avatar
I was just testing NYSH-AWD's ? , that error message is the result of the hub being plugged in before I could even get a device connected.
Old Sep 4, 2009 | 06:01 PM
timmahh's Avatar
I wonder if it senses the hub but w/ no device connected gives a failure? What would happen if you had a flash drive plugged into the hub then connected the hub?
Don't break your nav!!!
Old Sep 4, 2009 | 06:09 PM
bw5556's Avatar
...same result.
Old Sep 5, 2009 | 01:10 AM
PaulNY's Avatar
I think the easiest solution for one play one charge would be the DC to USB adapter for the charging item, and then regular usb for the playing....and if you're charging the iphone, you can still play via stereo BT and have the ipod play through the dock connector. I've been contemplating the same thing for a while, just never picked up the USB/DC charger. A usb hub would have been nice though
Old Sep 5, 2009 | 05:52 PM
Donmachete's Avatar
5th Gear
ipod touch 3rd gen
is anyone having problems connecting their ipod touch? there are times I have to try repeatedly to get a connect.
Old Sep 6, 2009 | 10:45 AM
bmode's Avatar
Turn off the bluetooth and see if you still have problems connecting. I have no issues whatsoever when I turn off the bluetooth on the iPhone 3GS, otherwise I have to reconnect the data pin for the iPhone, then it recognizes the iPhone. It all started after the 3.0 OS update. So much for backwards compatibility huh?
Oops, I just realized you said iPod "touch". I've never used one before, and the Apple website doesn't show bluetooth on the "touch"? Maybe turn off the WIFI then try it?
Old Sep 18, 2009 | 12:13 AM
Iceman52489's Avatar
Connoisseur of Aesthetics
the ipod touch will only work with the the AUX cable..it doesn't have bluetooth...
Old Sep 18, 2009 | 01:50 PM
09tlsteve's Avatar
I would think it would be possible to make a USB connector that would accept two or three devices but have a physical switch to change between them. Just a few Radio Shack parts and wire the switch out to a convenient place and then you'd just have to flip the switch to 'engage' the desired device.
Old Sep 19, 2009 | 07:20 AM
Xs05TL's Avatar
Actually, the second gen iPod Touch DOES have bluetooth audio capability. I have used it with a portable Bluetooth speaker, but I'm not sure of its compatibility with the Acura link.
Old Sep 20, 2009 | 10:57 PM
Oh werd...that's a pretty cool new feature!
Old Sep 21, 2009 | 02:31 AM
bmode's Avatar
Pretty sure it won't work with Acuralink as it requires to have tethering, which AT&T has not opened up to iPhones.
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
