Upgrading Audio - Alpine & JL Audio
A few 20A suggestions...
#03 - Washer
#20 - Moonroof
#19 - Driver's Power Seat Sliding
#21 - Driver's Power Seat Reclining
Or if you feel more comfortable using a 15A...
#23 - Front ACC Socket
I believe a 20A fuse is sufficient, and I suggest you use one that is not critical to the operation of your vehicle if it does happen to blow.
#03 - Washer
#20 - Moonroof
#03 - Washer
#20 - Moonroof
and i gotta prob downsize my box cause it just doesnt fit 3 tens
Good luck!
I ran it through my driver side wheelwell. Remove the wheel and the plastic cover and you'll see the cable from the hood release lever coming through. I pulled out the grommit and fed it through there. Before you put anything back together make sure the cable for the lever still moves freely. I think I used 8 gauge wire which still allowed for movement.
Good luck!
Good luck!
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
