Upgraded subwoofer
I'll take 3 thumbs up! Thank you!
I'm a former vendor her on AZ so I can't talk cost or promote my business in any way. If you have questions please feel free to shoot me a PM or email and we can talk about it off-line.
Flipster23 - Thank you for your props!
Originally Posted by potmilkz
oh shiet! how much did that run you?
http://cgi.ebay.com/ebaymotors/Custo...7#ht_500wt_722
I saw this on eBay a couple days ago looks like it's from the same person.
How easy is it to install
Noticed that the enclosure you are selling does not come ported? What are the advantages of porting or not? What is the added cost if you want to port? Do you mind me asking what type of sub and amplifier are you running?
This is the kind of thing Acurazine should be reaching out and promoting; a craftsman building quality custom components for our vehicles.
I've seen your 3G work, and it was top notch.
Originally Posted by Stew4HD
I bought an Uncald enclosure for my 3g. I liked it a lot. He does great work.
Originally Posted by HeartTLs
I've got some trunk rattle with my stock sub, would this make it much worse?
Rattles are a symptom of something loose or broken.
The deck rattle is a common one. The 3G had the same issue. The deck cover is too close to the speaker and not enough weather stripping/insulation between the deck cover and deck and/or speaker. I figure mine will rattle within a couple of years.
I removed the deck speaker in my 3G and used the Uncald box in the trunk... no rattle trouble after that!
uncald4, great looking work!
Do you plan on doing anything that will go into the rear of the trunk (closest to the back seat)? The location of your custom setup here will interfere with my golf habit.
This subwoofer has a grill but he didn't want it on.
Also, this enclosure shown is one of the biggest examples. Being that it's a ported enclosure it requires more air space which makes the enclosure bigger. Sealed enclosures would be half that size.
Originally Posted by BLACKURA_NY
Glad to see you back as a vendor... you did some ground breaking stuff for 3Gs many years ago
I am curious about getting a sub for my tl and had some questions.
I mostly listen to rap, and electronic music. what type of enlcosure would be better? sealed or ported? and what size do you think would give a better overall sound. 10" or 12".
also can you give a recommendation on a sub, no more then $200. and an amp recommendation?
I have two 12" type R's from several years ago (akthough i think one of them is blown) and an mtx amp.
