Running 4 Gauge Wire from Battery to Trunk
I'm trying to run a cable from the battery through to the trunk - but I was wondering aside from drilling through the firewall if I had any other options (eg. a open grommet near the driver's side).
How did everyone else do it?
Here is an answer:
https://acurazine.com/forums/showthr...light=firewall
No need to drill firewall. I ran a 4ga a month ago. If you remove the drivers side wheel well, there is a rubber grommet that you can run the cable through. You can't see it from the engine compartment. Must remove well. 4 clips i think.
Dont ruin your firewalls!
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
