reverse tilt door mirror
Old 03-19-2009, 06:38 PM
acura2009's Avatar
Hi
I've read through the manual and there is option to turn REVERSE Tilt "OFF" or ON** for one mirror, left or right.
How can I turn reverse tilt mirror for both sides ON** ?
Thanks a lot!!
Old 03-19-2009, 06:50 PM
crxb's Avatar
dont believe you can
Old 03-19-2009, 06:53 PM
RendanCLS's Avatar
Might be differnt on your tl, but on my older cl only the passenger side has reverse tilt mirror, the driver side mirror has no option to tilt when in reverse.
Old 03-19-2009, 07:03 PM
acura2009's Avatar
ok no problem
Old 03-19-2009, 07:08 PM
crxb's Avatar
w/ switch that picks the left or right mirror to adjust - if you leave it to the left or right - that mirror will tilt. leave the switch in the center position - then neither will tilt
Old 03-19-2009, 07:19 PM
acura2009's Avatar
yeah, im gna just leave mine off then :\
Old 03-19-2009, 09:37 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
Same as 3G.
In a while, you guy's will start to see the infamous "My mirror used to tilt, now it doesn't - help!!" threads.
mlody
12-04-2019 02:11 PM
blacktsxwagon
10-27-2015 10:12 PM
STC
09-23-2015 04:36 PM
Quick Reply: reverse tilt door mirror
