reverse tilt door mirror
Hi
I've read through the manual and there is option to turn REVERSE Tilt "OFF" or ON** for one mirror, left or right. How can I turn reverse tilt mirror for both sides ON** ? Thanks a lot!! |
dont believe you can
Might be differnt on your tl, but on my older cl only the passenger side has reverse tilt mirror, the driver side mirror has no option to tilt when in reverse.
ok no problem
Originally Posted by RendanCLS
(Post 10662714)
yeah, im gna just leave mine off then :\
Originally Posted by crxb
(Post 10662785)
w/ switch that picks the left or right mirror to adjust - if you leave it to the left or right - that mirror will tilt. leave the switch in the center position - then neither will tilt
In a while, you guy's will start to see the infamous "My mirror used to tilt, now it doesn't - help!!" threads. |
