Outside temp inaccurate
Old May 22, 2013 | 09:29 PM
radamo's Avatar
Had my first long drive today and loved my new TL. Noticed however that the outside temperature displayed in the cluster was off by 8 to 10 degrees. Is there a way to re calibrate? I see there is a way to change it by a few degrees. Is this going to require a trip to my dealer?
Thanks!
Rich
Old May 22, 2013 | 10:01 PM
dwest1023's Avatar
You can change it plus or minus 5 degrees. Keep in mind, that the tempt is only accurate at driving speed. If you stop and cut the engine off, the tempt gauge will not change until you drive altleast 3 miles without stopping.
Old May 22, 2013 | 11:20 PM
Steven Bell's Avatar
Rich,
If your car has been in a garage, it will take the thermometer time to calibrate.
Old May 23, 2013 | 06:30 AM
radamo's Avatar
Seems odd to me... Yesterday I was driving for over 50 miles and towards the end of my trip my temp was about 8 degrees higher than reported by local weather. This morning it was spot on my entire drive to work. Guess I have to determine what factors affect it.
Thanks for the replies and info.
RA
Old May 23, 2013 | 08:23 AM
Oswald Vater's Avatar
One big factor that will affect its reading is if your car is sitting on a hot surface it will pick up the surface heat which will make it read higher until you have driven it a while.
BTW, congrats on your purchase and welcome to the forum!
Old May 23, 2013 | 08:45 AM
Stew4HD's Avatar
^ Pavement tends to be hotter than ambient temp
Old May 23, 2013 | 08:54 AM
dwest1023's Avatar
RA
do not rely on local weather report. you can have different temperature in the same neighborhood.
Old May 23, 2013 | 12:16 PM
radamo's Avatar
Thanks so much. Really a sweet ride.
Rich
Old May 23, 2013 | 12:17 PM
radamo's Avatar
I was checking the temp after driving for over an hour. Hopefully by then it would have normalized.
Rich
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
01CLOwner
Oct 9, 2015 01:07 PM
Jboat
Sep 30, 2015 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
