Need Info Please! JL Audio Amp & Sub Question 4G TL
#41
2010TL, 07 600RR, 06 1KRR
While I agree for the most part, if you use high efficency amps (class D), their draw will be significantly lower than analog amps. Amps have come a long way since I first started installing car audio. Back then you needed multiple batteries, multiple caps, and possibly an upgraded alternator to achieve the same quality and spl that can be had rather easily today with little modification. But it's always better to prepare for the worst I suppose...
#42
8th Gear
Nice set up...you do it yourself?
#43
Okay... Ordered the Blue/Silver Stinger 0 Gauge kit, Matching Ground Wires, Dist Block, 4 Channel Stinger HPM3 20'ft cable, 2 Channel Stinger 6'ft cable. Should start the install this weekend!
#46
Okay Guys....
Got it all installed over the weekend! My friend does custom work and when I went to pick it up, All I could say was WOW! As far as the sound, It is CLEAN and CRISP. Drops nice but not too much ( Sealed Enclosure ) The C5's are LOUD!!! The Clean Sweep did it's job and I am a happy camper!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Here are some pics
This is a LED in the vent to let me know if the Clean Sweep is on or off. Green on/Red Off.
![](http://i17.photobucket.com/albums/b92/mlewis16/photo5.jpg)
This is the setup during the day!![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
![](http://i17.photobucket.com/albums/b92/mlewis16/photo3.jpg)
And this is what Is aw last night when I picked up my car... I was Amazed!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
![](http://i17.photobucket.com/albums/b92/mlewis16/photo2-1.jpg)
which was a surprise to see when he popped the trunk
Thank you guys for the advice and direction getting this done.
Here are some pics
#48
#49
You will lose the 5.1 setup unless you do one of the following:
1. sweep the front and rear deck, keep the center and side stock and add a line driver for the sub.
2. Drop the sweep and get a JBL MS-8 (but leave the center channel connected stock).
I started with 2 sweeps but moved on to the JBL MS-8. The MS-8 auto sums, time correcs and has a 31 band EQ.
I
Here is the thread related to my install.
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/4g-awd-tl-aftermarket-amps-speakers-install-758480/
Will update with pics of the MS-8 soon. My work was done professionally so I won't be able to answer your detailed questions about wiring.
Buy a Yellow Top battery and also some type of capacitor for your amps. I chose two Batcap Model 400. You will be asking alot from your battery if you don't.
Good luck.
I
Good luck.
BoricuaTL
04-08-2016 01:08 PM
Pegon95
09-15-2015 01:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
