How to install HID replacement bulbs?
I just ordered 6000K HID bulbs and figured it would be just like changing any other bulbs... Turns out, it's placed at a bizarre angle which lots of obstructions. The books says to take it to a dealer.
Do any of you happen to have instructions, pics, etc. on how to do this? I'm NOT taking it to a STealer to have them change it...
THX
THX
Haven't had the time...
Any of you know where to find a schematic? I took a quick look and saw I'd need to undo some screws from the bottom before I can pull away the wheel well lining....
After that, is it as simple as reaching up and replacing the bulb or do you guys anticipate it being much more difficult than that?
So... with that in mind... what did removing the bumper involve? Was it just a few screws and removing the bumper.. or did it involve taking other things apart as well? I'm trying to gauge whether it's even worth trying myself or pay someone to do it...
I'm curious to know myself if changing the low beams require taking off the damn bumper. Can someone clarify if this needs to happen? I would hate to have to take off the bumper just to change a silly little bulb. I just received my Philips Ultinon Bulb this afternoon in the mail and I am super anxious to fire it up. =)
For those that have changed their lights - what is the easiest way to access the low beams? And do I need to disconnect the battery to prevent any electrical discharge as per the instruction manual. Thanks guys!
http://www.flickr.com/photos/calvinchangflickr/5180237538/http://www.flickr.com/photos/calvinchangflickr/5180237538/ by http://www.flickr.com/people/calvinchangflickr/, on Flickr
I guess I'll attack the wheel well liner first before removing the bumper. Going to take the path of least resistance here.....lazy man's talk. Even popping off the covers was nerve wrecking esp since I only have 800 miles on her. Looks like it is either one or the other.
Damn what happened to the good ol' days of just popping open your hood and yanking out the bulb? And I thought working on my motorcycle (Also a Honda) is a PITA, this is just as bad.
This link is to instructions for replacing the sport grill. It shows how to remove the bumper also.
http://acura.bernardiparts.com/Image...e_BII42385.pdf
I hope this helps.
I hope this helps.
Why take off your bumper?!?! Its easy to do.
1. Turn your wheel in so you have more room to work
2. Remove the screw and a few of the plastic "plugs" (not sure what they're called)
3. Peel back wheel well liner, from there you will be able to see the back of head light.
Just replaced my OEM 4300k to Kaixen 6000k. My buddy helped me out. All you have to do is turn the wheel all the way to the side so you have room, take the plastic plugs out that hold the wheel liner, reach your hand where the bulb is located and remove the plastic cover that covers the hid bulb, and then pull the bulb out. Took less than 30 minutes to complete.
cycdaniel
Dec 17, 2019 10:58 AM
acura, acurazine, bulb, bulbs, change, cl, headlights, hid, install, installation, jacksonville, replace, replacement, tj, tl
