Changing out stock subwoofer
Old Jan 3, 2015 | 04:04 PM
CruNkcuBaN's Avatar
4th Gear
Hey all just tried something new and decided I wanted some more bass out of the stock system. Ordered a 8 inch type r from alpine, with a alpine 500 mono amp. I wanted a factory look so I will be hiding the amp. I also added additional sound damper.
So far this is what I have done.
Amp installed on the left side next to factory amp, fits perfect behind truck carpet.
Before
Ran the power wore thru the driver side fender per other post, but you can see any wires and ran it to the back thru molding and rear seat.
Still waiting on the subwoofer to come in the mail, should be all done my monday. I will be connecting the amp with a online converter with the amp power on built into online converter.
Old Jan 3, 2015 | 05:08 PM
Georgiey22's Avatar
Keep us in the loop, excited to see the final results.
Old Jan 5, 2015 | 01:18 PM
Echo42987's Avatar
Looks good! I also will be replacing this out pretty soon. Might go with a Hybrid Audio Claurus subwoofer though instead.
Old Jan 5, 2015 | 10:53 PM
CruNkcuBaN's Avatar
4th Gear
Well as far as for the alpine sub, there was a small difference, but I was not satisfiesatisfied with the results, since the sub works much better in a ported box, so I just ordered a ported box. The sound deadening did make some improvements and is worth it. But I am not sure if it is just the type of subwoofer I ordered.
Old Jan 5, 2015 | 11:07 PM
csmeance's Avatar
you are going to need a free-air subwoofer to work well in that location, but then you have to worry about the rear deck rattling!
IMO remove the factory sub and do an infinite baffle setup in the trunk/rear seat area.
Old Jan 6, 2015 | 11:16 AM
Echo42987's Avatar
I would agree with this, you do need a Free Air sub to work properly back there.
But doing a baffle setup is a lot more work then what he just did here. I'm assuming he was just working for a quick fix.
Old Jan 10, 2015 | 01:56 AM
andrewcjduong's Avatar
I'm in for updates. This is something I've always considered doing.
Also, how hard is it to remove all the rear deck cover. i would like to dynamat the rear like that as well.
Old Jan 14, 2015 | 09:56 PM
Any updates yet? Really interested in this.
Old Jan 21, 2015 | 07:32 PM
EnzosAcTL's Avatar
Me too...
Old Jan 23, 2015 | 10:56 AM
BuckTussa's Avatar
Basshead
It's not hard to remove. You do need elbow grease. You have to remove the back seat first, then the trim in the corners. The back dash pops out pulling up.
The back seat cushion is held in by clips right under where you would sit on both sides. Push down on the seat then pull the release. I think a few 10mm holds in the back . I dynamatted my back dash and doors too I can say it helps out some.
Old Jan 30, 2015 | 08:37 AM
TheMuffinMan's Avatar
Any chance you can be slightly more detailed?
I knew when I bought the car someone had removed the rear speaker deck, but when I got the car tinted yesterday we noticed they didn't replace the rear deck correctly so the center part is buckled upwards - I'm guessing a clip is out of place.
Old Feb 5, 2015 | 10:43 AM
BuckTussa's Avatar
Basshead
Old Feb 5, 2015 | 02:12 PM
Awesome!
Old Mar 24, 2015 | 12:32 PM
OnyekwereJI's Avatar
Echo,
Any updates on your setup? I'm looking to put a Clarus in the rear deck this weekend. Identical setup as the OP. Also going to Dynomat the rear deck and all doors. Any updates would be greatly appreciated.
Old Mar 24, 2015 | 07:43 PM
ej6sliver's Avatar
Any updates? What did op do to the stock subwoofer harness?
Old Mar 25, 2015 | 01:49 AM
csmeance's Avatar
probably used it for the signal for the amp!
Old Aug 16, 2018 | 11:21 PM
CL9_NY_nc's Avatar
Hey does any one kno whay chassis this is and is it possible to fit 2 12s in the trunk?
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
sockr1
Oct 1, 2015 01:31 AM
Aleax
Sep 11, 2015 11:31 AM
3GTLOwns
Sep 9, 2015 09:51 PM
