A/C question more of a problem
Old Jun 28, 2019 | 08:57 PM
Anicra's Avatar
My A/C seemly kicks off too often, Full Cold is not Full Cold. A/C is fully charged is there a bunch of relays I can check? Any suggestion are welcome. I am going to look thru the workshop manuals meanwhile. Just looking for input if anyone has had the same problem.
Old Jun 30, 2019 | 09:23 PM
csmeance's Avatar
clean the condensor in the front of the car and try changing out a/c relay and fan relays. Are you sure A/C is fully charged? Pressures change based on humidity and temp plus you can't really make sure it's perfect unless you do it by weight due to the PAG oil.
TVL65
Jun 16, 2015 01:56 PM
Scooter
Mar 21, 2004 09:47 AM
phil2
Nov 6, 2003 06:55 AM
