Bluetooth Audio Shutoff - Alternator/Battery Problems
Old Nov 7, 2017 | 06:20 PM
Blk10TL's Avatar
6th Gear
Exclamation Bluetooth Audio Shutoff - Alternator/Battery Problems
Having a problem with my car (2010 Acura TL) where the Bluetooth cuts out randomly when I’m driving . The problem got worse where the entire dash and navigation screen were flashing on and off also the car lost throttle response for a second. The car finally flashed a trouble code P0685 then a day later the alternator bearing started whirling before I could order the alternator the car the car started sputtering and died. The problem was the alternator plus a new battery. Now that those items are replaced the car’s Bluetooth still continues to cut on and off. Any help is appreciated.
Old Feb 28, 2018 | 12:42 PM
mossman77's Avatar
Bluetooth modules in Acuras are known to go bad. Repair or replace it. Removing the PCB from the case and sticking it in the oven at 450 degrees may fix it (reflows cold solder joints).
Old Jun 13, 2018 | 03:53 PM
lbettsuax's Avatar
same issue
I've been having the same issue with my bluetooth and it seems to keep getting worse. My bluetooth went off and on 4 times back to back within a 2 minute time period. I always thought it was a no cell or bad cell reception, until I came across this forum today. I've been wondering if this is a common problem or if it was just my car having the issues.
Old Aug 30, 2018 | 10:01 AM
clownshoos's Avatar
5th Gear
Dang it. That is exactly what I have been experiencing lately.
