Accessory Mode
Old Nov 9, 2019 | 07:35 PM
Jrsweetspeed's Avatar
8th Gear
Accessory Mode
All,
Working to install an aftermarket shift knob on my TL SH-AWD, no problems with the install, but without the shift button, the car will stay in accessory mode when placed in park.
There is no way that I am aware of to turn the car completely off with the shift button permanently depressed.
Has anyone else come up with a fix or workaround?
Old Nov 11, 2019 | 06:24 PM
csmeance's Avatar
the shift button should ground a wire to make the car think it's being pressed. You could always connect that ground to a switch that you can manually flip or have it trigger on with a signal of some sort so it works just like OEM. If I remember right it might be a purple wire that gets grounded.
Old Nov 11, 2019 | 08:06 PM
8th Gear
Where do I find the ground? Inside of the shifter knob button once its exposed? Thanks for the info!
san Antonio tl
4G TL Problems & Fixes
Jan 11, 2022 09:12 PM
acura_honda_30cl
1G CL Problems & Fixes
Dec 13, 2008 09:05 PM
Elephantman_nosefacehead
Apr 25, 2005 11:37 AM
CL-zero
Jan 20, 2004 11:21 PM
Casual
Sep 6, 2003 07:35 PM
