Accessory Mode
8th Gear
Accessory Mode
All,
Working to install an aftermarket shift knob on my TL SH-AWD, no problems with the install, but without the shift button, the car will stay in accessory mode when placed in park.
There is no way that I am aware of to turn the car completely off with the shift button permanently depressed.
Has anyone else come up with a fix or workaround?
the shift button should ground a wire to make the car think it's being pressed. You could always connect that ground to a switch that you can manually flip or have it trigger on with a signal of some sort so it works just like OEM. If I remember right it might be a purple wire that gets grounded.
Jrsweetspeed (11-11-2019)
8th Gear
san Antonio tl
4G TL Problems & Fixes
01-11-2022 09:12 PM
