Zaino??
Zaino??
I am looking to apply Zaino on my CBP.
There are so many different ones like z-2, z-7, ect.
Do I have to buy all of them and apply all?
Please give me some tips guys
the best thing to do is buy the following:
Z-7 Car Wash Soap
Z-2 Car Wax
Z-5 Car Wax
Z-6 Detail Spray
ZFX curing accelerant.
Go to autozone and buy a claybar kit from mothers!
Mix the z-7 with some water and use that as lubricant for the clay. Wash the car again to make sure there's no dirt/grit on it.
Apply Z-2 or Z-5 in a VERY thin coat. Let dry and then buff off.
Spray z-6 on a towel and wipe down the car (it's applying a spray wax). Then apply a coat of Z-5 or Z-2 (the other one that was not used in the first application). Let dry and buff off.
Spray z-6 again
Then go back to the wax used in the first application step and repeat the process with applying the wax. I usually put on 3 layers of each Z-2 and Z-5 to ensure its nicely covered. The z-6 provides extra gloss and protection for the paint and makes it easier to layer the wax.
Check out the wash and wax section for complete write up's and more info!
Z-7 Car Wash Soap
Z-2 Car Wax
Z-5 Car Wax
Z-6 Detail Spray
Spray z-6 again
i would ask this over at the wash and wax section...i dont use zaino products myself as they are overpriced in my opinion...there are alot of products out there that are just as good or better for alot less money....
do you plan on machine polishing prior to putting a final sealant/wax on it...
if you dont have a machine, now is the time to start looking at one...a porter cable is a good way to get started in weekend detailing, and your black paint will require some special care to keep it swirl free...
Received 6,470 Likes
Z-7 Car Wash Soap
Z-2 Car Wax
Z-5 Car Wax
Z-6 Detail Spray
Spray z-6 again
Z-7 Car Wash Soap
Z-2 Car Wax
Z-5 Car Wax
Z-6 Detail Spray
Spray z-6 again
Yes....this! I started out with Zaino products and was very happy. I have to say that the Z-6 is very good-better than others (in my opinion). I've tried 2-3 others, and will stick with the Z-6.
much like csmeance
I wash w/ the Z-7
clay
Z-2 w/ the ZFX curing accelerant
I wash w/ the Z-7
clay
Hard to argue with CRXB's results. Beautiful car!
I use Zaino waxes as well, but IMO, you must use a machine with polishes to get the marring/scratches out of the finish. I use Optimum Polishes, then top it out with a few coats of Z2/ZFX with Z8 gloss enhancer as a FP finish. Zaino is tough stuff and a good application will last you the year and still remain glossy.
I agree...BUT having gone from hand to DA polisher, I will say for the average person (and not NBP), Z2 with the accelerant. IMO, all the other Zaino products are somewhat extraneous. Nothing seals like it and hides imperfections though. It's very durable and gives a "good enough" appearance for the average car cleaning guy (not OCD detailing person...I WISH I could go back to not knowing what swirls were).
like one of the other guys stated, if your not ocd like me, then you will do fine without a machine...i notice you have a black car...enjoy the swirls, because you cant remove imperfections from modern clearcoat finishes by hand....it requires machine polishing and honda clearcoats marr and swirl if you breathe on them wrong...
