Wiring angel eyes as DRL
Question is, will both your DRL's and AE's be lit? Or is there a way to only have the AE's on (without losing your high beams). Also, once your headlights come (when DRL's are off), will your AE's be off?
It may be best to wire them to a switch.
I feel strongly both ways
The following 3 users liked this post by PsychDoc:
Ive also seen people wire it to the puddle lights or dome light so when you unlock the car it has a fade effect. The problem is that the light shuts off when the car is on.
Irish_Viking
AckTL05 is doing my headlight for me the kit I bought is from:
http://www.umnitza.com/acura-acura-t...4mtm65doqetkq6
I got the Orion V2 which is 5X brighter than the nearest kit, should be really bright.
I think its the same kit as omgthedonny
Irish_Viking
The turn around is around a week i think but hes got an exchange set so my car is only out of comission for an afternoon. Then I ship him mine back.
Irish_Viking
That's perfect if he has an exchange set. I think I might do mine as well if he still has an exchange set available. Are they difficult to remove?
Probably not too bad but its kinda cold out so im going to get custom car and truck to do it. The exchange set will likely be my current headlights.
https://acurazine.com/forums/4g-tl-photograph-gallery-296/tsx-r-vs-tl-lenses-848638/
Ive actually had alot of problems with them. I would not recommend the orion v2 halos. The manufacturer has a lifetime warranty on the parts but getting them out is alot of work.
Mine failed a month in, ive disabled them. He assured me it was a problem with just my batch and new ones would be fine. This problem has been widely reported so i decided to cut my losses and just leave them unplugged.
https://acurazine.com/forums/showthread.php?t=848638
I had a problems with my old halo setup as well. The ring was actually two leds and after 1/2 a year one of the power connecting points on the halo became loose/broken and only 1/2 the halo would light up. JnC offered to fix it for me and said he knew what the problem was but I didn't want to deal with the hassle; I had them removed.
Something is missing...my
6G TLX-S
In the 3g forums the issue is commonly found with the orion v2s.
They have a lifetime waranty but It really doesnt matter since its such a hassle to get at them again to replace them
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SUPRMN84
10-07-2015 09:46 PM
