What does FI mean?
4th Gear
What does FI mean?
Hey,
I have a blow fuse under the hood on my 09 TL awd and it says on the cover " FI sub" 15amp fuse. What does FI means? I lost my awd and ecu is giving me a bunch of codes.
thank you
Step
thank you
Step
FI = Fuel Injection = part of the full acronym PGM-FI = Programmed Fuel Injection
Fuse 14 is "FI Sub", because it's the fuse for the PGM-FI subrelays as well as other stuff:
Doesn't seem to control anything specifically SH-AWD related. What codes are you getting? Any specific error messages popping up on the gauge cluster screen?
The following 2 users liked this post by Riboflavin:
bigwavedave25 (08-14-2020),
justnspace (07-20-2020)
4th Gear
Thank you , Very appreciated
4th Gear
Riboflavin thank you for your reply , I had to put this issue on the side and now i am working on my car now.
Codes are 1035, 1055 and 0498 my FI sub fuse burns out and my sh-awd light is on .
I change one O2 sensor replace the 15 amp fuse clear my code and i was good for 3 days, On the third day i went for a drive stop for 20min then when I started the car all code came back and sh-awd light and burnt fuse. So i replace the other O2 sensor thinking it was the heater that was the problem. The same thing happen after 2 days burnt the fuse again .
I notice that when i put the fuse in you can hear a relay click on .
what else that fuse is used for ? Mitchell on demand it's not very helpful to diagnose the problem .
thanks
thanks
you're treating the wound, when you need to treat the symptom.
B1055 ACURA Description
The Relay Control Module monitors the Multiplex Control Unit Module (MICU). The Relay Control Module sets the OBDII code when the Multiplex Control Unit Module (MICU) is not to factory specifications
something is shorting out the multiplex unit
even if you replace the multiplex unit, the problem may still come back unless you find what is causing the short
very unlikely...P-codes start with 0. for example P0xxx
furthermore; googling p1035 doesnt bring anything up except for VVTI error, which that's a toyota thing...we have have variable cam timing as well, but it's called VTEC.
However, googling B1055 brings up a multiplex unit error, which falls in line with your fuse problem..because the multiplex unit controls everything.
you have a faulty MULTIPLEX unit, but what caused the unit to short/fail?
if we go back to the 2nd post and look at the fuse description;
#14 controls the multi-port fuel injection relay.
Nothing to do with variable cam timing.
Gang Gang
Also a heads up on the SH-AWD part ai didn't read. Your car will always go straight to FWD if any engine errors pop up for safety reasons. Less power means you can't distribute to both front and rear so rear shuts off and all power to the front for reliable driving to a safe location.
InFaMouSLink
09-12-2013 03:58 PM
westhaventl
08-13-2012 12:12 AM
takethis
09-04-2002 10:20 AM
