Weird idle after throttle body cleaning
I got a weird idle after cleaning the throttle body, I cleeaned the throttle body without removing so I had someone stepping on the throttle while I clean it out with crc throttle body cleaner and toothbrush while ofcourse wiping the dirt off with a rag. Although throttle response was 100% better now that I cleaned it, but I got this weird idle where it takes 2-3 seconds to go to 750-+ rpm from 1000-1250rpm after coming to a fullstop on the stoplight. Also, when ac is on the idle will jump from 750rpm to 1000rpm every 5sec(it could be normal engage of the ac compressor). Do I need to reset the ecu? How? Also if I do reset it, what do I need to do to relearn idle?
altair47 (04-12-2023)
MrVtech
02-28-2017 09:12 AM
guitarplayer16
06-10-2015 10:39 PM
