VLeds on 2012
Old Aug 12, 2011 | 05:39 PM
rodtl's Avatar
VLeds on 2012
Does anyone know if the Acura 2012 requires a relay harness. Vleds doesnt seem to have the 2009-2012 4G TL posted on their site. Will it work without the relay harness?
Old Aug 12, 2011 | 05:45 PM
potmilkz's Avatar
what are you trying to install?
led lights on doors? lol license plate lights? HID for fogs?
you really gotta be more specific..
Old Aug 12, 2011 | 09:37 PM
rodtl's Avatar
Sorry trying to install the DRL's bought them from a fellow AZ'er and he said that he did need them, is this true?
Old Aug 12, 2011 | 09:44 PM
01stang's Avatar
As far as I know u need some type of resistor to fix the error message. I don't think u need a relay harness(but it might be better to use it to run 12v vs 6v drl is running but I'm not too sure on that)
Old Aug 12, 2011 | 10:00 PM
rodtl's Avatar
I got the resistors just didnt get the relays as I was told you didnt need them Hope that is true!
Old Aug 12, 2011 | 11:47 PM
01stang's Avatar
Should put it on then post some pics I'm still debating on led drl or my yellow nokyas
Old Aug 13, 2011 | 03:39 AM
potmilkz's Avatar
check my threads, i have LED DRLS
Old Aug 13, 2011 | 12:09 PM
eazy's Avatar
WDP 4G
You're running nokyas on your DRL? Pictures?
Old Aug 13, 2011 | 03:01 PM
rodtl's Avatar
Thanks for the high jack JK! So the question still remains...are the relay's needed on the 4G's?
Old Aug 14, 2011 | 12:51 PM
rodtl's Avatar
Anyone running VLeds with their 4G TL without the relay?
Old Aug 14, 2011 | 01:09 PM
eazy's Avatar
WDP 4G
You know you could've went to V-leds.com. This is straight from v-leds website. I'm sure you need a relay harness if its included in the package
V-LEDS Part ID: TL_DRL_W_5K
# In Package:
1 Relay Harness
2 Plug n Play Resistors
2 9005 High Power Bulbs
P.S wasn't tryna jack your thread
Old Aug 14, 2011 | 02:00 PM
rodtl's Avatar
# In Package:
1 Relay Harness
Just pulling your chain about jacking my thread I did go to their site but it shows it for the 3G and not the 4G? Is this for the 4G?
Old Aug 15, 2011 | 01:02 PM
KB1Spec's Avatar
You need a module to by pass the error message on the MID. My friend and I are making a module for the 09-12 TL where there is no error message if you uses the LED for the DRL and full 12V power as well.
Old Aug 15, 2011 | 01:07 PM
eazy's Avatar
WDP 4G
If they're the same bulb type, then yea it is the same. I believe 3G uses 9005 too. I believe they sell just the harnesses alone
Old Aug 16, 2011 | 07:03 PM
rodtl's Avatar
Talked to the guy over at Vled and he told me to try the bulbs without anything at all but the lights, and then add the resistors and so on, he said that it might not really need the relay. They didnt have a 2012 to test it on so the reason I reached out to the community. Trying to see if anyone else is running V-leds without the relay? Guess I will see and report back.
Old Aug 16, 2011 | 08:37 PM
rodtl's Avatar
Mounted them without anything and the DRL warning came on, mounted them with the resistors and no warning but the lights seem a bit dim...kind of like them dim. My only issue now is where to mount the driver side resistor? Where is everyone finding a location to mount that resistor? And man do they get hot!
Old Aug 17, 2011 | 09:43 AM
01stang's Avatar
will the drl get brighter if u turn the high beams on?
Old Aug 17, 2011 | 10:31 AM
rodtl's Avatar
They do get brighter but I am wondering if they have the direct 12v source if they would get even brighter...kind of like them no so bright though. But still need to find a place to mount the resistors. I am going to have to remove the battery to find a location on the drivers side, the passender side was easy just not as easy on the drivers side. Also those resistors get really hot!
Old Aug 17, 2011 | 12:24 PM
KB1Spec's Avatar
We just tested out my car a while ago using Cree LEDs and regular SMD LEDs. We also re worked the resistor so it will not make it hot. But the Cree and SMD uses full 12V. The problem with the design of our headlamp on the 09-12 is that there is a shield in front of the high beam and since the Cree LED is direction, its is not as bright. SMD is bright because it is full 180 degree. My friend is getting a shipment of new resistor this week and will be testing on my 12 end of this week and give you some pic on output.
Old Aug 17, 2011 | 03:14 PM
rodtl's Avatar
Nice! The V-Leds have LEDS that are 360 degree's and some in front as well. At this point I am not sure if its due to me not having the direct 12 volts or thats just how bright they get, all in all they look good, need to mount that smoking resistor on the car somewhere. I am afraid that with the heat in Dallas and the engine compartment, these LEDS will not last long Not sure? I can mount some additional heat sinks to them but not sure it will make a difference sitting in the engine compartment.
Old Aug 17, 2011 | 11:15 PM
KB1Spec's Avatar
Give me a couple of days as we are testing out the LED and the resistor. We will do a burn in test on my car for QCing the product. Once it is good to go, I will post picture of the 360 degree SMD LED and the CREE LED set up. Stay tune.
Old Aug 18, 2011 | 11:18 AM
rodtl's Avatar
Cool, want to see that setup for sure! I ended up having to remove the battery and find a location for the resistors, they have a nice heat sink on them but I dont believe the are big enough to handle the heat. .
Anyone using the V-Leds DRL's with no issues? They ran for 20 minutes or so and man they are getting pretty hot!
Old Aug 22, 2011 | 12:42 PM
eazy's Avatar
WDP 4G
I just purchased a set of 194's from v-leds. I got an e-mail from V-HIDS?
Is V-leds become V-hids? both v-leds.com and v-hids.com work and both sites look similar except the names were different. Can anyone chime in?
Old Aug 22, 2011 | 04:23 PM
KB1Spec's Avatar
Maybe same company just that they have a "dba" status under a different name I guess.
Old Aug 22, 2011 | 11:36 PM
pickler's Avatar
i love V-LEDS! i ordered switchbacks for my sister's car, cant wait to install.
Old Aug 30, 2011 | 04:12 PM
KB1Spec's Avatar
Here is the promo code for jlclightings.com
ACURA10OFF
Have fun spending on the discount on LEDs lol
Old Aug 30, 2011 | 06:34 PM
rodtl's Avatar
Perhaps a dumb question but what is a switchback?
Old Aug 30, 2011 | 06:44 PM
chase101381's Avatar
Who is jlclightings.com, are they better than Vleds or iJDMtoy?
Old Aug 31, 2011 | 12:56 AM
KB1Spec's Avatar
Check my thread for the full 12V DRL LED setup
https://acurazine.com/forums/4g-tl-2009-2014-123/jlc-lighting-drl-led-module-09-12-tl-831247/
Old Aug 31, 2011 | 11:43 PM
rodtl's Avatar
Anyone? Switchbacks? What are these?
Old Sep 1, 2011 | 12:40 AM
KB1Spec's Avatar
Switchback LED bulbs means there are 2 color LED. Either blue/amber or white/amber. When constant, the white LED will light up but when you signal, the white LED will shut off then the amber will blink.
Here is an example:
http://www.jlclightings.com/3157_305..._p/sku_026.htm
If you order there is a discount code that they emailed me
ACURA10OFF
Old Sep 3, 2011 | 10:46 AM
rodtl's Avatar
Here is an example:
ACURA10OFF
Obviously not used for DRL's
Old Sep 19, 2011 | 05:32 PM
Treblig's Avatar
Can anyone tell me what bulb sizes are used for the center console, glove box and door lights? Thanks.
Old Sep 19, 2011 | 05:37 PM
potmilkz's Avatar
https://acurazine.com/forums/showthr...highlight=bulb
Old Sep 20, 2011 | 05:17 AM
TLsMD's Avatar
WINNING
will these switchbacks fit perfectly in the parking light/turn signal under the headlights?
and also will they match in color to the 4300 stock bulbs?
Old Sep 20, 2011 | 05:18 AM
TLsMD's Avatar
WINNING
and also is there anything else that needs to be bought for the switchbacks for them to work properly in our cars?
Old Sep 20, 2011 | 07:13 AM
smange's Avatar
Same questions as above on the switchbacks...I was under the impression that in order to do switchbacks on our cars we needed to tap in resistors. According to the site they say its simple plug in and it works. Any details potmilkz?
Old Sep 20, 2011 | 07:16 AM
TLsMD's Avatar
WINNING
yeah im interested in the switchbacks and im tempted to buy...i want the brightest and best ones....just not sure if i need to buy anything on top of them to help with error codes and hyperflashing....
Old Sep 20, 2011 | 09:52 AM
djtanveer's Avatar
all you need is 2 resistors, one per side, in order to stop the hyperflashing.
Old Sep 20, 2011 | 11:58 AM
KB1Spec's Avatar
It will fit but it WILL not match exactly to the stock 4300K because our HID bulb have a hue of yellow. Normally LEDs bulbs have a cool white color. More like super white. It's between 5000K to 6000K color. These are typically how the material are produce on LEDs.
I've been playing around with LEDs and really hard to match what you exactly want. I too wanted Yellow LED but the closest to true Yellow LED are those typical Amber color.
