Transfer fluid
Old Nov 16, 2015 | 06:51 PM
james21_h's Avatar
Transfer fluid
So I took my 2012 SHAWD TL to Honda dealership to get the transfer fluid changed. The front desk wasn't sure if my car has a transfer case at all so the manager came out and he said yes AWD cars have it. Then they took it in and had it changed. After I reviewed the receipt, it showed 2 quarts of DPSF was used to fill up the transfer case. Is that the right fluid??
I flipped through the user manual and couldn't find any oil specs for the transfer case. Is DPSF the right fluid??
Old Nov 16, 2015 | 09:42 PM
csmeance's Avatar
WRONG STUFF!!!
Tranny new oil DW1 Acura/Honda ATF
Transfer case new oil 80W90 gear oil
Rear differential new oil DW1
Go to them and get it fixed asap! It even says hyploid gear oil next to the drain bolt/fill bolt, and it says ATF on the rear differential that takes the ATF just like the trans.
Old Nov 16, 2015 | 09:51 PM
james21_h's Avatar
I thought DPSF is good for rear differential. But yeah, I will definitely call them tomorrow to get it sort out. They might put the wrong info on paper or did rear diff instead because there's no way you can pull in 2 quarts for the transfer case....
Old Nov 17, 2015 | 09:34 AM
hornedfrog's Avatar
honda has a part number for the transfer fluid. it's 08200-9014A. i went to the desk to pick some up and they were like "uhhh, what is this? oh we do have it, just a second..."
Old Nov 17, 2015 | 11:19 AM
james21_h's Avatar
So I did more digging and found this thread:
https://acurazine.com/forums/diy-faq...-fluid-792655/
So apparently DPSF is a 75W-90 weight oil and "can" be used as gear oil!!
Anyways, I called the dealership and they talked to the mechanic who did the job and he said he is 100% sure he put in 75W-90 gear oil.... but whoever wrote up the receipt used a wrong part #..... I don't know if I trust those guys 100%...
But if DPSF can be used as transfer fluid I think I am ok then...
What do you think??
Old Nov 17, 2015 | 12:52 PM
S power's Avatar
2010 TL SH-AWD
Difference is shockload resistance. Stop and go is where its at. Hence why mt requires thicker gear oil, once the clutch grabs, it impacts the gear surface.
So yes, its ok for now but for long-term will be determined.
Old Nov 17, 2015 | 03:26 PM
SirCarroll's Avatar
08200-9007A | Acura All-Wheel Drive Fluid (DPSF) - Bernardi Parts
Old Nov 17, 2015 | 05:56 PM
Reorge's Avatar
Originally Posted by csmeance
WRONG STUFF!!!
Not true for the OP. They list their car as a 2012. Starting in 2011 the rear diff requires DPSF.
Old Nov 17, 2015 | 10:07 PM
csmeance's Avatar
very true, here's the chart from acura:
iCrap
Jan 21, 2016 11:01 PM
CheeseyPoofs McNut
Dec 3, 2015 09:14 PM
chrisjw
Nov 11, 2015 04:35 PM
clubtc05
1G RDX Problems & Fixes
Nov 11, 2015 04:15 PM
Vizicore
Nov 4, 2015 05:55 PM
