STP Pro-Series Car Intake Valve Cleaner?
Old Mar 27, 2022 | 06:32 PM
Brewcity's Avatar
Hey all….has anyone actually used this product, and if so, what were the results?
Is this a good idea to use? Any help or advice would be appreciated
My TL now has 130,000 miles on it, and wanted to get the carbon build up cleaned as best as possible.
Thanks for all the help!
Old Mar 27, 2022 | 07:30 PM
altair47's Avatar
The J37 engine uses a Port Multi-Point Fuel Injection PGM-FI, which means that when the injector is injected, gasoline is sprayed onto the intake valves, therefore the valves are always clean and do not need to be cleaned.
Old Mar 27, 2022 | 07:37 PM
csmeance's Avatar
Carbon buildup is not a concern for our engines since they are port injected. You should always use a good fuel cleaner every oil change (put cleaner in gas tank). I use redline SI-1 and it works very well at keeping fuel injectors clean and fuel system clean.
Old Mar 27, 2022 | 07:42 PM
altair47's Avatar
From personal experience, I used Prestone AS730 Fuel Injector Cleaner 6 times and the only thing that helped me was removal and ultrasonic cleaning on the stand.
Old Mar 27, 2022 | 08:08 PM
BROlando's Avatar
Using top teir gas goes a long way.
You don't need to clean intake valve carbon, as noted by the other posters.
If your car doesn't have issues at 130K...why change what you've been doing?
Old Mar 27, 2022 | 09:15 PM
Brewcity's Avatar
very cool….thank you for the info and education! I really appreciate it.
Old Mar 27, 2022 | 09:21 PM
Brewcity's Avatar
thank you for the reply, and the recommendation of Redline.
I will go that route at my next oil change.
noclue02
5G TLX Problems & Fixes
Feb 22, 2021 09:27 AM
Robert Young
2G CL Problems & Fixes
Aug 1, 2019 06:28 AM
jaredb03
Nov 10, 2015 08:51 AM
axeman
Sep 24, 2004 02:35 PM
