Spectra Oil Pan
Spectra Oil Pan
I need to get a new oil pan. The drain plug threads got stripped so in turn it screwed the oil pan threads.
I found on rockauto.com a Spectra Oil Pan for $66
SPECTRA PREMIUM / COOLING DEPOT Part # HOP20A
Ive bought other parts from rockauto with no issues but I couldn't really find any reviews on Spectra and deciding should I go with it or get one from the dealership.
I called a local Acura dealer and they have theirs selling for $140 and $13 for the pan sealant.
What do you guys think? Would I be ok with Spectra or should I go with the Dealer?
check out acuraoemparts or oemacuraparts.com to see if they have a good in between price. Ultimately, it's just a pan, but having an OEM one for a similar price as aftermarket is always nice
Also check the BM, I do recall an oilpan coming up on there but not certain if it fit the 4G!
car-part.com, make sure you clean the old one off well and use a fair amount of honda-bond.
I suspect it would be a lot cheaper to install a repair heli-coil. I'm sure there are kits available over the internet. Or you can bring it to a machine shop and they can order and install it for you. Just another option.
^^^This. There are other options as well. I bought a used car one time that had a stripped oil pan bolt. At first I had an expanding oil pan bolt that did the job just fine. Then I bought a rethreading bolt that basically cuts new threads into the drain hole. It torqued down just fine, never leaked and lasted for years.
http://m.ebay.com/itm/M14x1-5-Oversize-Oil-Drain-Plug-for-Acura-Honda-One-Piece-Ships-Fast-/161748182539?nav=SEARCH
Reorge (07-19-2015)
IBankMouse
06-13-2020 12:53 PM
