Smoke LED Amber Mirror Signal Light by Unique Style Racing
How's it going Acura Community?!
My Name is Erick from Unique Style Racing and a few months ago we reached out to you guys regarding a test fit for Smoke Mirror Turn Signals with an Amber LED Output. As a result of that Test Fit we obtained through our community, we have confirmed fitment and have moved forward with the manufacturing of the signal lights. And we also took fellow members’ suggestions at that time to reduce the darkness of the smoke, so now will be more ideal of smoke.
I am happy to announce that we are fully stocked on the product and as the AcuraZine Community was at the forefront in assisting us with the product, we are offering a limited time introductory discount price for Acurazine members starting today up until 10-15-16 before the item goes back to its normal price.
Here are some photos of the final product:
To purchase the Mirror Signals you can purchase by CLICKING HERE
You can use the coupon code of " MRACTL2016 " to get $15.00 off of the original price
The fitment on the Mirror Signal Light consist of:
2007-2008 Acura TL (All Models)
2009-2012 Acura TL (All Models)
2010-2012 Acura ZDX (All Models)
which is set to replace OEM Part # 34301-STX-305 Right / 34351-STX-305 Left
Please EMAIL me if you have any questions at:
eg@uniquestyleracing.com
Thanks for your time AcuraZine!!!
Regards,
Unique Style Racing
Regards,
Unique Style Racing
The Original Shawdy
This gave me a great idea for a future mod.
they are all interchangeable.
swap takes less than 2 mins each side..
requires a semi long think screwdriver.
remove screw from inside mirror and pop off the unit, unplug and do reverse to put it back together.
so all this is a smoked side mirror? no upgraded led inside? brighter?
Cyberathlete101
looks good! very interested... but same same... would like to see it on a vehicle
pictures showing the following would be greatly appreciated...
darkness of the tint (Flashing and Not Flashing)
Brightness of the light (When Flashing)
Flash sequence
Thanks!
Flash sequence
Thanks!
I went ahead and ordered a set. I should be getting them by Thursday, I will post some before/after and day/night pics once received and installed.
What I can not find anywhere are some instructions on how to replace the exterior mirrors, I hope it is just as easy as take them off unbolt the cover and replace the turn signal assembly. I don't mind taking the door panel off or the mirror assembly, but I don't want to do something unnecessary. Can someone give some insight here?
i just filmed mine black. probably will look the same with some elemental protection.
lostprophet. do a video comparison between left and right inside a closed garage. i want to see the different in light output and visibility.
Damn, you would finally come up with this right after I don't own a TL!
Awesome, I would love to see some installed pictures!
For the life of me, I could NOT cleanly wrap the sidemarkers on my last TL...even when it looked okay, then I'd install and the opening was so tight it would bunch up.
1) Remove the front door sash inner trim.
2) Disconnect the Power Mirror Connector. (A)
3) While holding the Power Mirror (B), remove the nuts securing the mirror.
4) Release the catch (A) from the hole in the door, then remove the Power Mirror (B).
5) Separate the OEM LED Turn Signal Lenses (1 & 2) from the Outer Mirror Housings (4 & 11) by removing the screws (21).
6) Install aftermarket LED Turn Signal Lenses to Outer Mirror Housings (4 & 11) by tightening the screws (21).
7) Install the mirror in the reverse order of removal, and note these items...
- Make sure the connector is plugged in properly.
- Make sure the power mirror operates properly.
-greg
LostProphet (10-05-2016)
I received the lights one day before expected, they are actually made by Depo. I will try to power them tomorrow to see the brightness of the light. So far I am impressed with the built quality and how nicely they were packed. Sorry for the crappy iPhone pics.
carbonTSEX (10-06-2016)
Hmmm... depo's usually have moisture issues with fogging up. at least on previous cars/trucks i've had them on.
I haven't used them in years so hopefully their stuff is better now.
either way... can't wait to see them on.
UniqueStyleRacing has moved his business to MBWorld.org now with a slightly tweaked username of UniqueSRacing.
Feel free to visit him there.
UniqueStyleRacing
ZDX
10-06-2016 10:07 PM
UniqueStyleRacing
10-06-2016 10:07 PM
UniqueStyleRacing
05-30-2016 09:29 AM
