Shudder at speed.
Shudder at speed.
If I'm cruising at around 40 MPH, the car will sometimes produce a low frequency "shudder" that shakes the car. It fades in and out. Sometimes it will jump from a lower frequency to a higher frequency and back. Also, it sometimes feels like the transmission is slipping a little under the same conditions. I was thinking that it either had to be the transmission or the torque converter. The car has almost 140K miles and I drive it almost as hard as the Ferrari.
Looking to the AcuraZine brain trust for some ideas.
Thank you.
Thank you.
More information. The shifts are normal, not jerky. There is no problem during acceleration or deceleration. This only happens when I'm gingerly cruising at a constant speed with barely any throttle. Doesn't matter if it's cold or hot. And it has progressively gotten worse over the last few months.
Check your CV axles
altair47 (12-07-2022)
After an extended test drive with one of my mechanics, he said the symptoms were classic torque converter failure. Curious as to why no one on this forum has mentioned that, especially when there's an active service bulletin from Acura addressing the issue.
Most likely no one has encountered such a problem due to proper maintenance of the automatic transmission.
Thank you.
Thank you.
A scanner tool can be hooked up to your car and check that there are no issues with combustion at low RPMS, and as well can check throttle position sensor and other parameters before jumping to trans.
Dirty trans fluid can contribute to rough shifts and shuddering. If you drive the car hard, it's always best to change the fluid more frequently than suggested. The 6AT trans is a bit harder on it's fluid and it should be changed much more frequently than the manual states even when driven normally. I had this issue and the dealer did a 3x3 fluid swap before they had the software update. 3x3 fluid stopped low speed and cold judders
A tech can look at live data from the car and see if the torque converter is slipping, or the trans in the conditions you describe. If they don't have a high end scanner that can pull live data, then a torque converter stall test will show if it's slipping or not.
altair47 (12-12-2022)
just curious what year was your Honda odyssey that had the clogged EGR valve?
I had a 98 Acura RL that one of the issues was clogged EGR valve and manifold port, they made the manifold port too small and they did a recall to enlarge the port and Re-sleve it but the old lady that owned my RL never got it done
Frankyy (12-15-2022)
