Road Noise
Old 07-21-2012, 04:52 PM
icy CL's Avatar
Road Noise
Anyone do anything to lessen the road noise inside the cabin of a 4G TL tech. I intend to put b-quiet v comp on the front doors but thought i'd ask here first.
http://www.b-quiet.com/vcomp.html
Old 07-21-2012, 06:07 PM
ll_22's Avatar
change your tires, I changed to continental DWS and it is quieter. No doubt dampening will help but changing tires is easier.
Old 07-21-2012, 06:10 PM
Love Guru
mr_raja's Avatar
Hi OP,
I dont think insulating doors will make too much of a difference. To effectively reduce the road noise, the best thing to do will be to put insulation inside the doors and under the carpet. Just my .
Personally, I wont do it. I think the car is quiet enough as it is for my taste, but everyone is different.
Old 07-22-2012, 02:53 AM
6G TLX-S
Edward'TLS's Avatar
Received 1,156 Likes on 827 Posts
Dynamat the whole car.
Old 07-22-2012, 06:19 AM
it's a car-drive it
nj2pa2nc's Avatar
I find that road noise depends on what type of road I drive on. The quietest is newly paved asphault. Cement paved or roads that need to be repaved with lots of truck traffic make for a lot of road noise.
Old 07-22-2012, 08:27 AM
ziptied's Avatar
^this, the majority of road noise comes from shitty tires, or crazy tread. the rest of the time it is a wheel hub, improperly balanced tires or shitty alignment
Old 07-22-2012, 10:36 AM
BEAR-AvHistory's Avatar
Received 2,600 Likes on 1,581 Posts
+1 Road noise is generally tires. Am running oversized Conti DW Summers on my 3er with a big reduction in both noise & bump harshness over the factory Bridgstone Potenza that the car came with.
Old 07-22-2012, 08:58 PM
icy CL's Avatar
i know its the tires. But my tires still have a lot of life in them. Putting some vcomp stuff will cost me $200 max, i think. just getting some input. i'll look into replacing the tires to a different type when they are due.
Old 07-23-2012, 08:17 AM
ucf_bronco's Avatar
Yeah, I would put some sound dampening material in. I'd put it in the floor on the trunk and underneath the rear seats. The doors would help too of course.
I plan to do this some day as well.
Old 07-23-2012, 12:40 PM
stars_fan's Avatar
I think this is the best plan.
I'm going to do 2 boxes of vcomp for trunk & floorboards and then 1 box of extreme for the 4 doors. That's my plan but I doubt I will have time to get to it until this winter.
Old 08-21-2012, 08:07 PM
icy CL's Avatar
well, just for all to know. i took the doors apart and put v-comp on the door panel and dynamat extreme on the metal portion of the doors. to see if it made a difference, i first put the combination on the driver side door. drove around and could hear significant road noise coming from the passenger side. drivers side was much quieter. i now have the combination on three doors and will need to put on the rear right door. as a whole, it quieted the cabin quite a bit but not totally eliminating noise. another thing i noticed was the bass response from the stock speakers is much better i guess due to the better seal of the dynamat compared to the original plastic. doors also close more solidly with a solid thud. took me about 3 hrs per door just because i had to wait for the glue applied to the v-comp to dry. v-comp does not come with adhesive. i'm not sure if the adhesive i used will hold up - i used 3m 80 spray adhesive and put some aluminum tape as added support. I will check in a couple of weeks.
for those with 2010 tl tech, there are four screws to remove before taking the door apart. i can provide info if needed. took me a while to find the fourth screw. i kinda messed up my drivers door a little bit - i just try not to look at the minimal damage i created. not too obvious - except for me.
i bought two boxes of v-comp. one box is sufficient to do four doors. i intend to use the second box for the front firewall and floors to see if it eliminates even more noise.
Old 08-21-2012, 09:14 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Is it really that bad?
Old 08-22-2012, 08:42 AM
vinnier6's Avatar
tires....the oem michelins are horrible....i have had them on my last 3 cars, and cant get them off soon enough...if the next car i get has these tires on them, i am going to negotiate a different set of tire....
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Road Noise
