Replacement fog lights and staying on with high beams?
One of my fog light lenses is shattered and missing, even though the bulb still works I'd like to replace it. Is it possible to just get the lens? If not, it seems like aftermarket is the way to go on this part. Does anyone have suggestions on which specific one to get? I would like them to be bright and WHITE, not yellow, not blue. So if I got one of those LED ones, I'd want something in the low 4000K's.
Also wondering if there is a simple relay or bypass or something so the fog lights stay on with highbeams?
When I purchased my 6AT, the passenger side lens was broken, and the bulb did not function. I found a used fog light housing for ~$30 OTD on eBay, and at the same time, I ordered yellow halogen bulbs. So, when I replaced the entire housing, I also replaced the fog light bulbs. From the quick searches I did earlier in the year, it takes a relay setup in order to have the fog lights turned on with the DRL's. You'll have to do some thorough research, though.
