Remote Key Fob Not Detected... BEEP! BEEP! BEEP!!
In regards to the beeping we get when you step out of the car and close the door with the key fob in your pocket... is there any way I can reduce the volume or turn it off entirely?
It's starting to get annoying and it would be great if there was some way to lower the sound.
Stay Out Of the Left Lane
Received 1,237 Likes
Are you leaving your car running and walking away that frequently?
2009 SH-AWD TL
09 TL with tech, to adjust the alarm volume push the start button twice to enter accessory mode.
Go to keyless memory settings > chg settings >meter setup > scroll to adjust alarm volume. Make your change and then save and exit. Unfortunately you can only lower the volume, no option there to switch it off completely.
mynameisjacob (07-09-2014)
Sorry but I don't think this works... I just tried it tonight but volume of the beeps remain the same regardless of low, mid or high. Maybe this alarm setting changes something else?
soupi
14
11-15-2015 11:15 AM
