Please Help SH-AWD Error Multiple CEL’s
Old Oct 31, 2024 | 12:28 PM
nonameslim's Avatar
3rd Gear
Just purchased this 2010 TL SH AWD. I knew it needed work but I am willing to do it. Got a few things I want to ask you experienced Acura folks. So Ill list the CEL codes and other stuff and let me know your opinions.
2010 Acura TL SH-AWD odometer reads 140k miles, carfax shows over 200k so likely rolled back or new cluster installed.
AWD error - run about two or three minutes then cones on and awd stops working. From my research likely low fluid or weak batter. Thought?
p2647 - oil switch sensor did not have continuity, going to replace. Possibly something else common? Going to replace gasket and screen also while im at it.
p0497 - could be many thing. May have exhaust leak, bad o2 sensor, evap valve? Whats most likely or best place to start. Already replaced gas cap, non oe
p145c - likely related to p0497.
Loud vavletrain - heard this is common, checked hydraulic belt tensioner seems to be working fine, likely pitted cams?? Was thinking anout throwing in some 10w30 or 10w40 to make it quieter…lol
could any of those issues (maybe a vac leak) also cause soft brakes? I bled all of them except for 1, the bleeder broke (new caliper on order) but the other three had no air in them that i could see.
if you read all this thank you so much in advance. I am very poor and want to approach this the most financially responsible way I can.
Visdoom
4G TL Problems & Fixes
Aug 20, 2024 04:41 PM
Gregster62
Mar 3, 2023 03:57 PM
rsteagall
Oct 11, 2018 06:43 PM
ssgnco
Oct 17, 2016 07:24 AM
hinspire93
Feb 3, 2013 01:06 PM
