Outside weather temperature sensor
Old Aug 3, 2011 | 09:41 PM
jaydm98's Avatar
I had to disconnect the outside weather temperature sensor because I had to take off my front bumper. It shows -40 degrees now. How long does it take to reclalibrate to the correct outside weather temperature? Thanks in advance.
Old Aug 4, 2011 | 11:54 AM
JM2010 SH-AWD's Avatar
I recall reading in the manual that there is a way you can calibrate the o/s temp sensor if it's not reading accurately. Since mine seemed OK I didn't pay much attention, but it's in there somewhere.
Old Aug 4, 2011 | 12:02 PM
misu's Avatar
You can calibrate it by a few degrees through the steering wheel controls, if it's at -40 my guess is it's not connected.
Old Aug 4, 2011 | 12:13 PM
jaydm98's Avatar
Thanks. It is connected now since I put my bumper back on. It showed -40 while being connected. If it wasnt connected it would not show anything on the dash at all. It ended up recalibrating took about 30 mins though.
Old Sep 2, 2014 | 03:54 PM
Try2bmine's Avatar
Weather display showing ----F
Hello
Is there a way to test and fix this issue? I bought an old 2009 acura TL base model. I am not seeing the outside temperature at all. When I start I see -40 for few seconds and then nothing
Old Sep 2, 2014 | 04:05 PM
acrdr's Avatar
You have to perform a procedure to drain all power disconnect neg and pos from the battery and then touch the neg and pos cables together for about a min to discharge all power then reconnect the battery
Hope it works
Old Sep 2, 2014 | 04:33 PM
potmilkz's Avatar
Yup reset the car
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
