Ok what am I missing. Hid extra for fog light kit not working. '12TL
'12 TL AWD Advanced
Hello everyone..
I finally got around to installing my hid kit tonight after having my car for 6 months+. I'm using the hid extra h11 stealth or slim ballasts. So the kit seems simple and basically idiot proof which is why I'm stumped why mines not working. I've searched the forums and found someone's guide to install it, which was great but didn't make mine work!
Here's what my wiring setup looks like. The only not plugged in goes to the factory wiring. Or am I doing something wrong here? This sucks as it's going to be the only time I'll likely have to work on this for the foreseeable future.
To anyone out there thinking of waiting to do an install i think you can do it in 20 minutes if you don't have issues like me!
forest (10-23-2015)
'12 TL AWD Advanced
forest (10-23-2015)
'12 TL AWD Advanced
Do I need one or two relays?
http://www.hidextra.com/universal-hid-relay-harness/
forest (10-23-2015)
Many people around here have used kits just like that without any problems. You shouldn't need any extra relays. It should be 100% plug and play. Obviously, without seeing how you are hooking it up, I can't be sure that it isn't user error but it should be pretty self-explanatory. There may be an issue with the kit itself. I agree with Justin about contacting the company you got it from to see if they can help you troubleshoot. Have you tried plugging the regular bulbs back in and firing them up just to make sure you didn't blow a fuse during the initial install?
forest (10-23-2015)
'12 TL AWD Advanced
Relays are fine and dandy but if I'm going to install them, I'll be getting a brighter set of lights not 35watts.
Thanks for your reply!
'12 TL AWD Advanced
2010 TL SH-AWD
Some kit comes with the input wires reverse. Meaning the harness that connects to the car is backwards. On your hid harness, switch the black and red around. Try it.
forest (10-25-2015)
'12 TL AWD Advanced
The power wire(red) goes to the white/offwhite whatever color isn't black. I was way to tired to install it when I did. The lights look great!
'12 TL AWD Advanced
I'm ignorant to the what the significance of my car being a '12 is? I'm going to install a relay when I get my switchbacks!
Attachment 102415
forest (10-29-2015)
Cutoff line from a few feet away:
Jerry"O" has a detailed review and better pictures here:
https://acurazine.com/forums/fourth-...type-s-915221/
polish_pat
10-19-2015 05:39 PM
