OEM Remote Start Question
Old May 16, 2014 | 11:29 AM
big10purdue's Avatar
The 2014 MDX has a pretty sweet remote start fob that doubles as our normal key fob... so only one fob is necessary. It's also ~$200 less (than the TL) on the MSRP. When calling the dealership to ask if they're interchangable, the parts department was a bit unsure as he was under the belief that most of the MDX harnesses and wiring was pre-fabricated on the assembly line (hence the lesser price). Im wondering what's missing from the TL wiring that couldn't be added. I would pay extra to condense both fobs into one... but don't know if the additional work ispossible.
Any insight or experience on this?
Thanks...
Old May 16, 2014 | 11:37 AM
potmilkz's Avatar
if the plugs dont fit, then it dont.. try to see if you can take a look at both mdx and tl kits. if they look the same, then a high chance they work..
Old May 16, 2014 | 04:16 PM
Edward'TLS's Avatar
6G TLX-S
The remote starter module talks to the car's PCM.
So the MDX module must communicate with the TL in the exact same way as for the TL module, in order for the swapped system to work, even if the plugs all look the same.
Old May 17, 2014 | 06:38 AM
beach109's Avatar
No comparison, and no similarity in system. The MDX uses an entirely different architecture, and new key system. Plus, in the MDX, and future Acura's such as the TLX, remote start is pre-wired and then the new remotes and module just have to be added and programmed to work.
The TL, RDX, RLX, ILX, etc. use the older I & II systems with a secondary remote that then turns off when you open the door. No other system can be used on these vehicles, unless you go aftermarket, which can also be done.
The MDX's system will be the way moving forward on future products.
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
