Is it Normal That AC does not feel cold enought
Hi everyone, I bought my new TL tech pkg. about a week ago and coming from a Passat 2.0T, In my Passat if I set on 69 it made the interior real cool but in TL I have to set on 64-65 to get to the same feeling, any comments?
A great temp setting, but probably not accurate in the VeeDub. Read up on how the Tech package manages climate in the TL - pretty amazing. You might want to adjust your comfort zone accordingly.
AcurAdmirer
All I can say is that we were in Phoenix a couple weeks ago at 118 degrees F and it was nice and cool in the wife's TL with the temps set to 72.
Shouldn't need to go clear to 64-65, unless you're taking about at startup beofre the car is cooled down.
If anything mine is too cool. On an 85-90 degree day if I set my temp at 70 it gets and stays very cool in the car. The climate control system in this car is amazing.
I feel strongly both ways
I've noticed that the A/C doesn't really work too well until you're going consistently more than 30mph. After that it's pretty darn strong. Not quite as powerful as the A/C in the Lexus ES350, but good. It helps if you push the recirculate button on the bottom right of the center stack.
One question. Do you have the climate control set on auto?
Good point... I always use "Auto" setting and have found that anything cooler than 72 for a longer period is too cool for me (and I typically like it cool).
At startup, I typically put it on 70, then bump it "up" to 72 or 73 after the engine's warmed up.
I noticed similar thing. In my Passat I used to set it at 72 in summer and winter and it works well. Now in the TL, I usually have to set it at 70 on or 68 or so on a hot day(90s) to feel cool. Bought it in late June so not had chance to experience winter yet.
Hey cool! I came from Passat 2.0T too.
I never use the auto funtion because I can't the stand the auto setting makes the fan blow on max whenever you get into a car that has been toasting under the sun. So I set the temperature and adjust my own fan speed.
wow, I want fan on high when the car is toasty hot. My fan cuts down rather quick once its done its job
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
CostcoFanAUS
09-18-2015 06:05 AM
