New headlight bulb
New headlight bulb
So I have a 2012 TL and I recently changed to the bicolor switchbacks. I noticed that the switchbacks have a true white color while the headlights have more of an beige or off white color (typical stock HIDs). My question is has anyone changed the bulbs of their headlights to make them more white?
I assume that I wouldn't have to change anything other than the bulb since it has HIDs stock, right?
Stock HID bulbs are 4300K. I recently changed out both of mine for the 6000K bulbs offered at iJDMToy (specifically, these ones). I wasn't going for a colour change, as I didn't see the stock bulbs as "yellow" as some suggested. That is, until I swapped them out. My mechanic swapped out one, but apparently the driver's side was "too hard", and although he claimed it was the same colour, they clearly weren't. So for a week or so, I drove around with 4300 on the left, and 6000 on the right. There is a significant difference.
I like the new bulbs. I went with the iJDMToy bulbs because I've had good luck with their stuff in the past, and they were a relatively cheap alternative.
So you didn't do it for a color but did you notice a color change while looking at the lights? IE were they more yellow? I assume you can just change the bulbs to a 6K plug and play too right? No need for relays or ballast?
My (former) mechanic's words, not mine. That said, I did swap out the driver's side bulb myself, and it is a PITA. Might be more pleasant if you have small hands. There's a good walkthrough (with pics) on one of the threads that I found even more useful than the service manual.
Yes, the stocks are more "yellow" compared to the 6000's, as one would expect. That said, I had no problem with the stock bulbs, and, until seeing them side-by-side, did not feel they were yellow at all. I don't think there's anything wrong with 4300's myself, and from what I understand, they will throw more light than the 6000k's. Haven't experienced any diminished road lighting, but I haven't had much opportunity to drive late at night for the past little while.
bulb swaping is easy. jack up the front of the car, turn your wheel pointing inward so you have space, take tabs of fender liner and start taking it apart from there..
i believe its there is a cap you have to take off, then turn counter clockwise to take off the igniter, then press clips, squeeze and it should release the bulb.
I've heard of others doing it that way...sounds like it might be a better way to go.
Sock, how would you say the light output is compared to the stock bulbs? I had 6k bulbs swapped in before, and light output seemed brighter up close. But in the distance, it was a noticeable drop compared to the stocks.
As I said in post 5 above, I haven't really had an opportunity to try it out in the dark. This time of year, this far north, the sun is up at 5:30, and doesn't go down until after 10 (meaning later than that for actual "darkness"). I only swapped 3 weeks ago, and just got back from vacation (without the car).
Not sure if pics will really show you much, as they are bound to be influenced by ambient lighting, camera quality, etc. But...here are some quick ones with my phone. Unfortunately, I didn't take any when I had one of each bulb in.
I took the wheel right off, and the liner right off...and it was still a PITA (though taking the wheel and liner off was a big chunk of the work).
hmmm looks a little bluer then i expected... looks like i may need to look for 5k bulbs and 5k looking switchbacks... wanted to get 6k headlights since its easier to find switchbacks that match 6k
