Lost 2012 Acura TL Key
After coming back from a Hockey game one night I noticed the next morning my key to my 2012 Acura TL was gone and no where to be found. I had Acura roadside open the door to my car after searching my apartment and did not find it in the car or in the apartment. This raised several questions:
1) Can you drive the car without the key If I dropped it at the game and drove away from the key?
2) When the Roadside assistant opened the door and the alarm was going off the dash said press break and ignition to start much like it does when I am in the car with the key. Does this mean the key is in the car or nearby or does it say this regardless?
1. Yes
2. Wow, no key needed? That's BS
Have you looked between the driver's seat and center console? Or (in the dreaded Black Hole) under the passenger seat?
NCMD (10-15-2013)
Thanks for replying. Would the car beep If I drove away without the Key? Also it said press break and push button but when I did nothing happened. So Im wondering if it says this always or if the key is nearby. And if it is nearby why didnt the doors just open when I tired them?
Maybe check your trunk?
NCMD (10-15-2013)
I called a dealer near me (I am trying all avenues before I just give in and spend 250 to reprogram the car) and he said he went to a car to test out what I asked him and the autos all said the same thing when you open the door. It must just be a programmed response when the door opens.
I have come to the conclusion I dropped it at my apt and someone now has it. You can drive it without the key but he said it will beep which it did not. I also must have locked it when I got home since the doors where locked which further supports me having the key at that time. Since it is not in my apt as far as my one day through search has gone it must be lost in the grass for good or someone has it.
Blaze9 (10-16-2013)
Also in regards to the trunk/inside car location of the key. The dealers said that the car will not lock if the key is in the car since it is the wireless start key (2012 Acura TL Technology Package). The trunk will also not lock if the key is inside according to them. Not sure if this is the case since I have had many responses from many people but it makes sense.
Keeping TL until 2029
The car will warn you that the key is not in proximity. I was dropping my wife off and drove off for about 10 meters and a warning shows up in MID screen. Also, I have tested locking the car using switch on door, drop the key in car somewhere and close the door, and it will not lock. My son loves demoing the key in truck trick. You need to have Tech Package (keyless) start option on you TL.
Sorry for your loss. Seems like you have trouble keeping your keys. Looks like you're gonna have to shell out the bread for new keys and reprogram the car. Sucks. Expensive lesson.......Be more mindful of your keys!! This happened to me. Now I developed the habit of NEVER taking the key out of my pocket until I get home. I then put it on the hook near the door. My spare key is in a box in a safe and unforgettable place.
Still a Noob!
1:The car can not be started if the keys/remote were not in the car when you attempt to start it. Not to mention not being able to open the door if the keys/remote were not close to the car to start with.
2: If the key/remote was dropped outside after start up and driving away. Your MID should have been blinking like a mad man tell you key/remote not detected. Hard not to notice it but your car will remain running till it has been shut down but can not be restarted without remote/key in range afterwards.
3: Car doors can not be locked via external handle button if keys are in the car/trunk. It however can be locked via internal door switches if I recall.
Hope this helps some and stop losing your keys
The following just happened to me yesterday.
My wife thought she had lost the driver 2 key fob but apparently, it slipped out of her pockets and fill in between the seat and the center console and here are couple of things....
1. I was still able to lock the car while in possession of driver 1 key fob via the external handle button and thru the driver 1 key fob.
2. I was told by the SA that while they can disable the lost key for the ignition, the lost key fob can still open the doors.
3. Even with driver 2 key fob inside the car, if you open the doors with driver 1 key fob, and start the ignitiion, the MID will display DRIVER 1.
4. SA told me that the key fob does not have to be inside the car to start the car. If the key fob is in around 30ft range, it can still start the car.
Nitin
09-30-2015 08:22 PM
