Lighting!!!
Old Aug 31, 2011 | 11:50 AM
  #81
nickceci51's Avatar
Vanity and Courtesy
Can someone let me know which led's to order from V-LEDS... I think i know which vanitys to pick, but if someone could provide a link to both the courtesy and vanity lights it would be appreciated!?!
Old Oct 17, 2011 | 08:48 PM
  #82
macguitar's Avatar
I'm resurrecting this thread My 2012 TL SH-AWD is scheduled to arrive in November, but I want to order my LEDs now and be ready!
Can anyone (maybe Mr. Skytech) with a 2012 take some photos (please!) of the light bulbs (without the lens) for the license plate bulb and the bulbs for the door (courtesy lights)?
For the doors, are there lights only for the front doors or the back doors, too?
Finally, for the trunk, how many bulbs are there? And if anyone has a photo of that bulb, that would be helpful.
Thanks *so* much in advance!!
Old Oct 17, 2011 | 09:15 PM
  #83
englishtony2002's Avatar
Originally Posted by buckvegas
2009 ACURA TL
Low beam headlamp
HID-D2S
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
992 (7440A)
Tail light
LED
Stop light
LED
High mount stop light
Assembly
Fog/Driving light
H11
License plate
168
Back up light
921
Front sidemarker
168
Rear sidemarker
168
Step/Courtesy light
158
Trunk/Cargo area
168
Daytime running light
9005
Those are the replacement bulb numbers for the 09 TL. If your talking about the front turn signal next to the fog lights, I have changed mine out to Led switchbacks, so they run white when the lights are on, and switch to amber when you signal. You can get these on V-Leds.com. If you change the turn signal bulbs to LED you will have to install resistors to avoid hyperblinking, do a search there are a few DIY on here. I am not sure about changing out the DRL's, I was interested in this as well, but almost everything I read in different threads people were having issues with the DRL warning light coming on.
Great list, but the trunk light is incorrect. The trunk uses a 32mm festoon bulb. Also the step\courtesy will take a 168 provided it is not too bulky.
Old Oct 17, 2011 | 09:29 PM
  #84
The LED switchbacks look fantastic but MUST be used with the load resistors. The load resistors sink enough current to ground to simulate the current taken by a filament bulb. they will get HOT, most are 6ohm 50watt, at 14volts that is a little over 2 amps, a 27Watt filament bulb (like the flasher on the TL) consumes 2 amps, that is how the value is calculated. It is VERY important that they are not in contact with plastic parts and that the grounding is done correctly with minimal impedance. For the front flashers the load resistors are connected to the thicker of the two colored wires going to the bulb socket (the black is the ground wire, the thinner wire is the sidelight filament). You can then connect the ground end of the load resistor to the black wire or, better still attach a ring to the wire and attachs securely to the underbody lip spoiler bolt to the far left and far right, the load resistor leads will just reach in the configuration. Finally use double sided tape to secure the load resistor the the frame.
You will not be disappointed, mine came from www.jdmiToy.com, $42 including resistors.
Old Oct 17, 2011 | 10:00 PM
  #85
Macguitar, I became somewhat obsessed with getting rid of all yellow incandescents and switched to LED's. License Plate and Door Courtesy all use 168 (probably the most common auto bulb there is), you need 4 in all, great value from here http://www.amazon.com/gp/product/B0047RV8WG
there are none in the rear doors on a TL. The Trunk uses a single 32mm Festoon style bulb.
http://www.amazon.com/gp/product/B00337KNAO
See my earlier post with regard to DRL's and LED switchbacks for the front sidelight\turn signals. These come from http://www/jdmiToy.com
Search the site for the TL 9005 LED DRL kit, complete with Load resistors (which you must use), and also the 1157 switchbacks, for the sidelight\turn signals.
Say goodbye to nasty yellow lighting.
Old Oct 17, 2011 | 10:04 PM
  #86
Mistake in web address
APOLOGIES - The web address is www.ijdmTOY.com for the LED lighting.
Old Oct 17, 2011 | 10:14 PM
  #87
macguitar's Avatar
Wow! Thanks so much for the info, much appreciated! One question I have is about the direction/type of bulb. If you look here:
http://www.v-leds.com/194-168-158-LE...orLanding/true
They have 360, Flank, and Forward. Which type would be the best for License Plate and which type for the doors? Thanks again!
Old Oct 18, 2011 | 07:51 AM
  #88
Foward style for the license plate (as you only need downlighting)and 360 for the doors (still need downlighting but these are instalkled horizontally rather than vertically like the license plate bulbs) would be my recommendation. Just be careful that you do not choose anything too bulky, a standard 168 filament bulb is pretty small so space is at a bit of a premium especially in the doors.
Old Sep 4, 2012 | 10:41 PM
  #89
listrats's Avatar
2013 ATS 2.0T Premium
Will these flank style ones work?
If they have all the LED's on one side how do i know that i wont need to flip it for it to work as it usualy needs to happen with LED's
Old Sep 5, 2012 | 09:48 AM
  #90
Hogan9166's Avatar
I used the flank style for my puddle lights, but installed blue for something a bit different. They're pretty bright, though.
Old Sep 5, 2012 | 10:41 AM
  #91
listrats's Avatar
so they arent polarized? Since its only one bulb on one side dont want it to have to face up lol
Old Mar 24, 2015 | 01:37 PM
  #92
just1nsama's Avatar
2013 TL SH-AWD TECH 6MT
What size are the vanity and dome bulbs, dont seem to see any info about it in this thread.
Thank you
Old Mar 24, 2015 | 09:10 PM
  #93
BDoggPrelude's Avatar
Thank you
The dome lights are LED's stock and are soldered to the circuit board. They are not easily replaced. There is write-up on here by a member that managed to swap them out with some different SMD LED's but it's not just a basic swap like the other bulbs. As for the vanity lights, I think the standard V-LED vanity LED bulbs should work just fine:
VLEDS
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
