LED headlights
LED headlights
I am wanting to change my daytime/high beam, fog, and get led switch backs for my car. What are some bright 6000k led out there and that are a good brand and good output light pattern. Some brands i looked into are
Auxbeam
Fluxbeam
Vleds
Opt7
Anyone let me know they are or other bright leds
Auxbeam
Fluxbeam
Vleds
Opt7
Theretrofitsource has good LEDs
Keeping TL until 2029
I used Putco. It uses a ribbon heat sink. No moving parts...
https://acurazine.com/forums/fourth-...-953482/page2/
shaade (08-22-2018)
I went with the cheaper iJDMtoy LEDs. They come with resistors so you won't get any error lights on the dash. They aren't freaky bright, but still enough to do their job and in the dark the oem headlights are bright as hell alongside them.
No issue. The newer LEDs are so bright so running lower voltage is not an issue on DRL. I used Putco's on DRL and Fogs since 04-29-2017 through 2.5 Canadian Winters and they are still going strong. If your TL is 2012 or newer, I would get the Morimoto Fogs.
Check this out:
https://acurazine.com/forums/fourth-...h-beam-990827/
Many options for LED DRL/High Beams now. I have been running my Putco LEDs since April 2017! Because I have older TL, I just upgraded the Fog buibs to LED as well. If you have 2012-2014 TL, you can get Morimoto LED Fogs which are really nice.
Check this out:
