J37a4 swap with j37a2
Need a new engine I think mine is done after a month and a half of owning it. Found a j37a2 engine within my price range, can I swap my j37a4 with that. What is the difference between the two?
The Acura catalog says that J37A2 09-10 RL is not interchangeable with J37A4, but J37A2 11-12 RL can be installed in place of J37A4. The main thing is that the crankshaft sensor is in the oil pan, and not on the timing belt sprocket. Write a link to the engine you want to install.
If I was faced with a situation of replacing the engine, then I would install J35Z6 from the front-wheel drive TL. Here's a good suggestion, oil changed every 6k miles. https://ahparts.com/buy-used/2012-ac...k1a11/290053-1
I guess since it’s 09-10 it won’t work but do you know why not? Or would the 11-12 fit on to my transmission alright?
not sure how responding on here works but the link for the one I was looking at is https://www.ebay.com/itm/12581225029...0AAOSwR59kCrJN
Don't worry about the transmission, it's a standard design.
I want to know more about the only engine in your province with the gerzy bear supercharger on it. Got a link?
the serpentine belt went and wore a hole through my timing belt cover around the crank, got under the timing belt and threw the timing off like a month and a half into owning it. Best case I only need a valve job done cause I was only going about 40-50 kmph
