J37A4 Camshafts blueprints and specs
Old Oct 18, 2025 | 10:43 PM
specnaz's Avatar
Does anyone has in some Alldata or other specs for these two camshafts?
I've pulled mine out and would like to make a CAD model of it however since they are wrecked I can only get approximate measurements and almost impossible to measure lobe angles and splines on them, as they are asymmetrical
I'm entertaining idea that if there's enough interest I could probably have them made and sold for reasonable price so our J37's can run again for reasonable price
Old Oct 19, 2025 | 02:34 AM
specnaz's Avatar
Basically i need to know tangent radial direction of each lobe of each side that is not a base circle to get it right
Old Oct 19, 2025 | 03:25 AM
specnaz's Avatar
this is what i sketched up tonight but lobe angles and tangents is what I would need to make it perfect , then send for a quote
Old Oct 19, 2025 | 05:25 AM
altair47's Avatar
Good luck with the making.
Maybe it would be better to make a rockers?
Old Oct 19, 2025 | 01:39 PM
specnaz's Avatar
I have access to cnc lathe and 4340 steel rods, that part is easy and if made in at least 50x series it can be cheap , what i don't have is the mill turn center or grinder to make the profiles , and I don't have measurements for lift and cam angles tables because this tangents need to be mathematically calculated .
i believe that's what P2R did to get his billet ones.
Rockers wouldn't be economical I don't think because they don't fail as often and are complex to make too, and not much demand for them.
Hardened 4340 steel wouldn't get eaten as easily as cast iron either
Old Oct 19, 2025 | 08:27 PM
altair47's Avatar
Good luck to you in this matter!
The rockers are eaten away together with the shaft and must be replaced together.
And they are very expensive, so replacing to J35Z6 is always the best option.
Old Oct 20, 2025 | 08:06 PM
altair47's Avatar
  1. specnaz has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Old Oct 20, 2025 | 08:09 PM
specnaz's Avatar
I deleted all and still says I reached a quota непонятно
Old Oct 23, 2025 | 10:35 PM
BadVibe08's Avatar
I'm taking my 2012 into the shop next week as it's making strange tapping noise most noticeable above 3k rpm. Is it well known that the cams were defective or is the thinking that oil starvation ruins it?
How much are we talking to get a new car and installed if you know?
If my car could last that long, I might be interested in a replacement.
Old Oct 23, 2025 | 10:40 PM
altair47's Avatar
This work makes sense if you do it yourself, because the shop will take 2-3k just for the labor.
iamitman
Apr 18, 2014 08:43 AM
hornedfrog2000
Jan 12, 2007 06:16 AM
stangg172004
Feb 1, 2005 12:03 AM
red99cl2.3
Feb 10, 2004 09:55 AM
