How to remove shark fin antenna?
It'd probably be easier to remove if you took off the tail light. Remove the clips/large screws, pop the plastic piece off the center of the trunk (where it locks), pull away some of the lining and unscrew the 3 hex shaped screws, once they're off hit the screws lightly with the back up a screw driver, now that lights are no longer snug in place plug them out from the outside of the car.
You'll need a flat head and a wrench. If you need more detailed instructions give me a call, I'll go to my car as you're doing it.
Or we should link up when you have time maybe you can help me swap em
Shark Fin Antenna:
Just go inside your car and take out the cover of your 3rd brake light. From there pull the roof panel carefully and slowly. There are some plugs so it is not hard. Try not to pull out the pillar on both side. When you pull down the roof liner, don't BEND it too hard or else you will see some indentation of the liner. OK hard part is taking out the shark fin. You need to go all the way in on the back window to find the shark fin. I think you need a 12mm or 13mm to loosen the nut. Once the nut is off there is a plug. Disable that plug. That plug is for the XM radio. Once that is done, your antenna should be off.
Like I said, hardest part is to loosen the nut that holds onto the antenna. But remember if you pull the roof liner, don't bend it all the way. Bend it so you have enough space to loosen the Antenna.
Have fun
Have fun
IMO jus find some one who can do the job withput removing the antenna when i did my 08 they guy made it look like he took it off u didnt see any cuts lmki can refer u to him...he is in queens btw
Shark Fin Antenna:
Have fun
Have fun
I need to remove the antenna anyway I want to have the antenna wrapped as well
i just bought these for my reverse lights...
https://store.ijdmtoy.com/ProductDet...ED_T10_SKU_C02
let me know what you think...
are u putting HIDs, if so i would be a little worried about temp issues.
HID reverse lights?
naaaaaaaaaaah
naaaaaaaaaaah
dainmezron
10-16-2015 06:56 PM
us285126
10-02-2015 02:03 PM
