How to connect dashcam
I'm thinking of sticking an Ojocam in my 2012 TL but I want to make the wiring as neat as possible.
I'm considering connecting it to the wire connected to the rearview mirror. Is there a way I can do this without losing the auto-dimming with the mirror? Like, getting a splitter so the wire can power both the camera and the mirror?
If not, I suppose I could stick a wire through the liner and connect the camera straight into the main console.
Look up threads on hardwiring radar detectors. Should be the same process.
Stay Out Of the Left Lane
Received 1,244 Likes
^^^^ This. Also double check the volts/amps draw of the dashcam vs. radar detector but believe you should be fine.
skabei (05-31-2015)
skabei (05-31-2015)
This is all assuming you only want the dashcam to work while the car is running. There is another thread recently started where the OP wanted to be able to record what is happening when he isn't in his car. Apparently he has paid $2500 out of pocket in repairs to his car from other drivers that have hit him and didn't leave any sort of note.
I didn't know that the power to the auto-dimming mirrors is cut off in reverse.. If that's the case then I don't think I'll be doing it that way.
How can I get the dashcam to run while I am away from my car if it detects any impact? Will that require the dashcam to have the feature as well as a battery or will I have to connect the camera to the main console?
I'm not sure how the other OP was looking for the cameras to work but am guessing he/she was looking for it to record constantly vs. on with impact. For constant on operation you would need to find a circuit not tied to the ignition. Something like power locks, power seats, dome light etc.
skabei (05-31-2015)
I don't have a 4G, so I can't speak to functionality, but I'm not sure why and cant think of a functional reason the mirror would operate this way
Here is the other thread I was referring to - https://acurazine.com/forums/second-.../#post15454137
And in terms of running a wire down the A pillar, i was able to wire my radar detector into the fusebox without pulling the cover. I ran the power cord along the headliner and down the A pillar and on down to the fuse box by just pushing the power cord in between windshield and the A pillar. I pushed it in with my fingers to get it started and then use a small flat head screwdriver to push it behind the cover.
skabei (05-31-2015)
I'll look for this other thread and see how he did it. I'm now looking into how difficult it would be to remove the interior cover for the a-pillar to stick the wiring through. It looks like I'll need to replace the one-time-use clip that holds it down on one of the ends.
skabei (05-31-2015)
Careful running the wire down the A pillar. There is an airbag in there. If you go that way, remove the A pillar to be able to see where the wire ends up, make sure the wire is on the side of the airbag and not on top of it. Shit happens...
The following 3 users liked this post by Tonyware:
Youtube has tons of information on dashcam installation. When I installed my 2 channel system, it took under two hours and I took my time and did it slowly. Pulling the weather stripping is very easy and tuck in all the wiring under the headliner (to run wires from rear camera to the front). I used passenger side fuse box and used accessory fuse and dome light fuse for power sources so I can record while vehicle is parked and can record impact or motion sense triggered. Make sure you get a battery saver so dashcam doesn't drain your battery if it's parked for extended time.
Also look at this site for installation.
How to Install Dash Camera - Blackboxmycar.com
The following 2 users liked this post by vtec260:
NBP04TL4ME (06-01-2015),
skabei (06-01-2015)
Agreed and a good safety tip. My wire is literally sitting just inside the A-pillar cover and can't imagine it would interfere with airbag deployment in anyway.
What's a battery saver? I was thinking about the battery since I don't often drive on weekdays anymore (I subway to work now) so this is something that I should be looking into.
navtool.com
31
11-16-2015 08:30 PM
