Help w/splash guard installation
Old Feb 24, 2012 | 10:53 PM
s2k+TL's Avatar
Trying to install OEM splash guards on my 2012 TL. Front are done but rears I cant screw them in even with a stubby philips. I installed the bar just fine but the actual guard is too close to the tires and I can't get a short philips in place. My only thought is to remove the wheel/tires. Any other ways? Don't have a torque wrench to torque the wheels to proper spec.
Old Feb 24, 2012 | 11:27 PM
under9hell's Avatar
I didn't install the splash guards, but from what you're describing something like this may work?
http://www.toolking.com.au/product_i...85853_zoom.JPG
Attached Thumbnails Help w/splash guard installation-dscf1969__85853_zoom.jpg
Old Feb 24, 2012 | 11:35 PM
MyT6MT's Avatar
I had to remove the rear tires to do it. It took 5 minutes.
Old Feb 24, 2012 | 11:42 PM
s2k+TL's Avatar
what is the torque when you tighten the lug nuts back? 85 lbs?
Old Feb 26, 2012 | 07:22 AM
3rdGenHybrid's Avatar
95 ft lbs
Old Feb 26, 2012 | 07:23 AM
I used a 1/4 ratchet and Phillips adapter and didn't take the wheels off
Old Feb 26, 2012 | 10:01 AM
vinnier6's Avatar
exactly what i did....
Old Feb 27, 2012 | 01:01 PM
s2k+TL's Avatar
ended up taking the wheels off. torque is 94lb feet on the lug size 22s.
Old Feb 27, 2012 | 02:46 PM
ferrcad's Avatar
I will third that... Works fine with the 2012 Advance tires and rims...
Old Feb 27, 2012 | 09:34 PM
TallmanTL's Avatar
8th Gear
does anyone have pics of what the look like on the TL. I just bought a 2012 SH AWD and living in the Northeast, i feel like i need them
Old Feb 27, 2012 | 09:48 PM
under9hell's Avatar
https://acurazine.com/forums/4g-tl-photograph-gallery-296/graphite-2012-tl-base-update-847494/
you can look at the pics of the white TL at the bottom of the thread.
Old Feb 28, 2012 | 08:19 AM
ferrcad's Avatar
Here is a thread to my new 2012 TL... It shows the splash guards installed but no real close ups...
https://acurazine.com/forums/4g-tl-2009-2014-123/2012-tl-sh-awd-advance-mayan-bronze-umber-finally-home-833095/
Old Dec 13, 2015 | 01:55 PM
omgitsspooky's Avatar
Hey all, allow me to piggy back off this thread as I'm also have rear splash guard "fitment" issues to be exact.
As I was trying to install the passenger side rear splash guard, I noticed one of the holes wasn't aligned. It was way off! Here are the pictures of both sides of the rear.
Am I missing something?! I'm following the instructions. Please help.
Driver's side rear is good.
Passenger side rear... wtf?
Old Dec 13, 2015 | 05:14 PM
Here's an overview of the rear splash guards.
Did I get the wrong part?
Old Dec 13, 2015 | 05:31 PM
Shoot, I think I did based on this diagram. The rear guards should not mirror each other like the ones I received!! What a pain in the ass.
Old Dec 13, 2015 | 06:36 PM
I'm guessing Base TL's and SH-AWD TL's have different configurations?
Old Dec 13, 2015 | 08:35 PM
PinotGrigio's Avatar
I'm pretty sure they should be the same( base/sh).... If all four of your guards look the same there is a problem!
Old Dec 14, 2015 | 05:05 AM
Well, the fronts mirror each other and so do the rears as you see in my pic above. But looking at that diagram, the rears do not mirror each other.
Could someone please take a quick peek at their rear splash guards and determine if they mirror each other or not??? I'm also waiting back from acurapartsforless.com to see what they're gonna do about this.
Old Dec 14, 2015 | 05:13 AM
I've had them and they are not supposed to mirror each other .
le^2
Feb 18, 2021 10:44 PM
CatalinaILX
ILX
Nov 6, 2015 05:20 PM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
EE4Life
Sep 11, 2015 10:13 PM
