Help Fog Light Question
Old Nov 2, 2016 | 04:36 PM
ron3.7's Avatar
2013 acura tl shawd stock fog light 12 volt, 55 watt, h11 bulb does any body know how many lumen that puts out. Maybe I can replace with and after market bulb that's a little brighter and throws off a blue color like the stock headlights I heard after a certain lumen number of brightness the bulb gets bluer.
Old Nov 2, 2016 | 10:14 PM
csmeance's Avatar
The color is KELVIN and the intensity of the light is LUMENS (brightness)
You can change the factory Halogen Fogs to an HID bulb with an HID kit.
3000K (yellow) - Best visibility in fog
4500-5000K - Factory Headlamp color
5500- Crystal White
6000- White with hint of blue
After 5500K, you loose light output (lumens), brightest is the OSRAM CBI 5500K @ 3200 lumens.
Old Nov 3, 2016 | 03:17 AM
Anicra's Avatar
The Lumen® - G8 LED Headlight Conversion Kit is 6500lm combined so like 3250lm per. I have set of Lumen I use during the summer (3years) and a set of regular photonic yellow for winter. The LEDs did not help much or if any during heavy fog or borderline blizzard condition however do like them during the summer nights.
BTW Csmeance isnt real, it is the Acurazine AI avatar, Terminator alpha version T 0.0001
Old Nov 3, 2016 | 09:26 AM
get HID's if you want actual functional fogs.
https://www.theretrofitsource.com/hi...oto-elite.html
5500K will be a little bluer than stock.
Old Nov 3, 2016 | 09:46 AM
raystl's Avatar
I hate HID's installed on lamps... especially open lamps. Unless you don't mind blinding people. Plus, no cut off line in a open lamp looks tacky IMHO.
Or go with these LED's.
https://acurazine.com/forums/4g-tl-a...stions-947868/
njresendez
Sep 30, 2016 02:51 PM
winn746
3G TL Photograph Gallery
Sep 7, 2016 08:50 AM
pri
2G TSX Problems & Fixes
Jul 29, 2016 11:36 AM
SupremeOpinion
Feb 8, 2016 06:16 PM
paekshin
Jan 14, 2016 08:08 AM
