Headlight replacement
Old 06-20-2019 | 03:33 PM
04SSMnMD's Avatar
Has anyone bought replacement headlights from ebay that are made by 1A Auto. I tried to remove the residue on my and noticed a crack in one so I might as well just order new ones. If I can find a decent set of used O.E.M.'s for a good price I rather buy those but if not I guess it would be replica ones to buy.
Old 06-20-2019 | 03:36 PM
Stick with used OEM, far superior innards than the aftermarket ones.
04SSMnMD (06-21-2019)
Old 06-21-2019 | 01:01 AM
csmeance's Avatar
ebay/facebook is best bet to find used OEM parts at killer prices! If you want new, it'll be acuraoemparts.com use code acurazine for 5% off. Aftermarket lights tend to get moisture or look off in color.
The following 2 users liked this post by csmeance:
04SSMnMD (06-21-2019), echodigital (06-21-2019)
Old 06-21-2019 | 04:28 PM
sockpuppet's Avatar
I'm typically a big fan of OEM, but I have to disagree with you on lights. The OEM have a tendency to crack, particularly in climates with significant temperature swing. That's a design failure, and not a hallmark of "higher quality". I've seen aftermarket headlights for the 4G (can't remember which brand) and they were practically indistinguishable from OEM. As for fogs, I ran through several sets of OEM (paying through the nose for the privilege), before finally "settling" for some Depos. The Depos have lasted for years now.
So while I typically go OEM, if I need to replace another headlight (I've already had to), I'll likely go aftermarket.
Old 06-26-2019 | 10:31 AM
Kingcredible's Avatar
I've bought from 1Aauto before. The quality of the parts are ok for a beater car but I wouldn't put em on my TL. Aftermarket headlights are always a gamble, The ones I got from ebay didn't align correctly with the hood of the car and its mounting points. It resulted in a very hard to close hood and a headlight that was anchored at only 2 points. Let us know if you find a quality and cost effective alternative to OEM headlights.
mr shickadance
03-09-2014 01:55 PM
Kennedy
03-30-2011 03:35 AM
LacViet
2G TL Photograph Gallery
33
10-13-2006 07:15 PM
Shnook718
07-13-2006 01:52 AM
stillwaterd
11-20-2005 07:37 PM
