Has anyone dynoed an AWD TL yet?
#41
Sounds good, I am expecting to meet Peter around 1:30-2:00 in the afternoon Saturday. Someone else is supposed to be making a trip from NJ to pick up some parts so I will be here around 1:00. Even if you can't get a filter by you, It would still be interesting to get a baseline so we can compare it to Peter's MDX.
#42
#43
#45
#48
Results are in.....
we are off to a great start. The awd system on the acura tl and mdx are pretty advanced. It seems as if you have to hit the gas at the right spot to engage the dyno to read properly. If you hit the gas pedal too late or too early the diffs seem to lock up and does not want to let the car accelerate.
Some trial and error and here we have it for the 2009 acura tl: second gear-190.7whp 165wtq third gear-165.4whp 145wtq
With a drop in filter and full exhaust we have achieved 191whp 170wtq. we have gained 32whp and 26wtq over stock. all runs done in 3rd gear.
I will have dyno sheets up shortly. we are taking a lunch break.
#49
#50
You'll Never Walk Alone
So is it fair to say the TL makes more hp but the less torque than the MDX based on the dyno results?
that's a huge gain considering this dyno reads pretty low by the way!
#51
It makes sense the MDX has more torque.
Oh and the dyno for my TL we got 165, but that was at 6100 rpm whereas Acura says peak horspower is at 6300 with redline at 6700. He didn't rev the hell out of it which is fine by me but I think we would have seen 170 if the AWD would have allowed for multiple clean runs side by side. As he was explaining, it's difficult to get continuous pulls down without the AWD trying to compensate. So yes, the 'numbers' are low, but it's just a baseline for testing modifications. ;]
#52
Your car would have easily hit 170 to redline.The important thing is we got two good base line runs to start with your car.
#53
#54
Dyno Sheets...sorry for the delay!
This first Dyno sheet is of the 2009 Acura TL. These are Stock runs. One is done in second gear. The other run is done in third gear.
![](http://img525.imageshack.us/img525/5609/stocktlrunsyo1.jpg)
This next sheet illustrated the Air/Fuel ratio between Second and Third Gear. Notice Third gear is leaner in the mid range.
![](http://img394.imageshack.us/img394/2919/acuraairfeulir0.jpg)
Now we have Peter's Acura MDX comparing his Bone stock run to his latest run which includes: Full Exhaust w/ high flow resonators and mufflers, and a K&N drop in air filter. Notice the HUGE gains compared to stock. We have gained 32.2whp and 29wtq with a full free flowing exhaust and a drop in filter on our dyno which reads significantly lower than most.
![](http://img136.imageshack.us/img136/9653/stockexhaustso8.jpg)
Next we have Peter's Air/Fuel plots ranginge from stock-Full Exhaust.
![](http://img509.imageshack.us/img509/5997/fullexhaustairfueljn1.jpg)
Last but not Least we have all of Peter's runs ranging from stock-full exhaust. Notice the improvements of each modification in power to air fuel ratio.
![](http://img360.imageshack.us/img360/4698/fullexhaustdynoyl3.jpg)
#56
I can't wait to see what the TL will gain with those same mods! thanks for the pics.
I also notice a jump in the TL 3rd gear curves, I guess that's when the VTEC "kicks in"? I don't notice that in the MDX though.
#57
I would assume that has something more with the tach pulse which is hooked up to the car. There are two different ways to graph a car on a dyno dynamics dyno. The 1st way is hooking up a tach pulse on one of the coil wires. The 2nd way is using "roller speed". You can use roller speed by putting the car at a certain rpm and speed. Ex. 50mph 3rd gear= 4500rpm. You punch that in and it will estimate tach pulse that way. Both ways work fine but I will only use roller speed if a car has lots of valve train noise and upgraded ignition systems which can throw the tach signal off. Gets pretty technical.
#58
Nice results but keep in mind that the exhaust on the TL has a much higher flow than the MDX. I doubt we'll see as much increase doing the same upgrades. Really curious to find out though. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
DG could you guys post the dyno sheets that show past the peak HP of 6100rpm? Unless you didn't go over 6100.. I would like to see how fast the torque and HP trails off until the redline/lmiter. Thanks!
#60
#63
Connoisseur of Aesthetics
1 Post
What exactly is a drop-in filter? Where does it go? Is it like the air filter you get when you get an Oil/Air filter change?
K&N website mentions air filter of part 33-2403 for the AWD and FWD. Was that the one you got?
#64
AZ Community Team
Received 7,770 Likes
K&N "Drop In" filter is just K&N high flow engine air filter. It "drops in" in place of the stock engine air filter.
The part you link is probably (99%) the one they are talking about.
#66
Here are some pictures Peter, his friend, and I took tonight of Peter's Acura MDX at my shop. Peter noted that he was going to add "high flow" resonators and mufflers, and that is exactly what he did. We will have more dyno testing done this weekend. Here are some pictures of this beautiful custom exhaust.Remember that the car was dyno tested with the custom downpipe and x-pipe. We will be testing the high flow resonators and mufflers.
![](http://img376.imageshack.us/img376/8430/045lz5.jpg)
Here is the custom downpipe that will connect with a very nice X pipe.
![](http://img177.imageshack.us/img177/2918/040uv9.jpg)
Top notch welds.......
![](http://img75.imageshack.us/img75/6335/041gw4.jpg)
True dual exhaust running into high flow resonators.
![](http://img177.imageshack.us/img177/7567/020ns1.jpg)
High flow resonators with heavy duty thick hangers for extra strength.
![](http://img177.imageshack.us/img177/8559/019wu3.jpg)
Another shot of the thick hangers used. This one to support one of the high flow mufflers.
![](http://img408.imageshack.us/img408/3557/052tc0.jpg)
![](http://img75.imageshack.us/img75/5821/048va4.jpg)
![](http://img301.imageshack.us/img301/3262/051gk0.jpg)
Oval blended tips with a nice touch. 110% better looking than stock.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Like I stated above, we will have dyno results for everyone this weekend. Peter and I are excited to do some real world testing on the first full true dual exhaust!![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Please do not mind some of the pictures as they came out a little blury. I can garuntee the dyno sheets will be perfect! Stay tuned as we will be making a video of this next dyno session!
joflewbyu2
08-18-2019 10:38 PM
