Fog Light Replacement -- Need Help
I just bought Phillips 5000k H11's to replace the OEM bulbs on my 2010 TL SHAWD. Last night I tried doing the installation and failed miserably. I read the instructions in the manual (and followed them), which told me to take out the wheel-well liner, and spoiler to gain access to the bulbs. It seemed straight forward and simple.
When attempting to unhook the Driver's side bulb, the manual says "press the tab and pull down". Pressing that tab down was nearly impossible. I also tried taking the housing out -- which would be a 1/4 turn counter-clockwise. It would only move 1/8th a turn at best and not budge. I gave up and tried the passenger side. To only find that the windshield washer reservoir completely blocks any access to the bulbs.
Is there any way to do this without taking the bumper off? It seems like taking my bumper off is an unnecessary 5hr process to change a simple light bulb. Has anyone else run into a similar problem? Any help would be much appreciated!
Thank you!
Thank you!
pdemers (04-04-2014)
However, I'm not sure how they got passed the windshield washer reservoir on the passenger side without removing the bumper.
Thanks, I found that when I was searching for the correct bulbs last week, but the pictures don't display. That seems to be exactly how I did attempted the installation.
You can easily just pick up the windshield washer container up and place it on top of the radiator. It is not bolted in and is removable. The H11s are a bit tight when it comes to loosening so you do have to put some strength into it when u twist. If you are unable to twist then try to use some pliers.
pdemers (04-07-2014)
Get access to under the car... ramps or just slide under if you're stock height... pull the two side inspection panels... they are on either side under the front of the car... access is easy from there... I ran the relay harness and pulled the front bumper since I was doing other things at the time... but went back and fixed a few things from those panels... it's a couple of push pins and 10mm bolts...
I actually have to correct myself. Sorry but I gave you the wrong information. You CANNOT remove the windshield washer container. I was actually thinking of the antifreeze/coolant container. You can actually lift the car and reach in from under the car to remove the fog lights.
Thank you for your help!
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
