ESP code 61
Old May 30, 2025 | 02:37 PM
raffijian's Avatar
ESP code 61
While driving my 13 TL MT today, I got a EPS error code 61 and my power steering locked up. I see there is a TSB for it.
First time I‘ve had this happen since I bought the car and have 142k on it.
Dealer said they will charge to inspect but will waive if it applies to the TSB. Anyone run into this issue and had problems with dealer not covering it? It is now working ok after the car has been turned if for 10 minutes.
Old May 30, 2025 | 03:02 PM
csmeance's Avatar
I had a bunch of flashing lights and got the module replaced for the EPS, did not work after a restart and the steering was super heavy around the same mileage as you. I have a 13 Auto model. Also have them check for any recalls such as for the airbags!
Old May 30, 2025 | 03:44 PM
raffijian's Avatar
My lights were not flashing when the error message came on. I did read in the TSB if it was flashing they would cover. If not flashing, would I be on the hook for repairs? Thanks.
Old May 30, 2025 | 06:03 PM
If correct TSB is displayed below & you have code 61-04 and the EPS indicator 'comes on steady' then you should be in link flint?
sache
Jul 5, 2011 07:11 PM
AcuraCar99
Oct 26, 2009 08:42 PM
rob-2
Aug 17, 2008 04:49 PM
mesmerize
Jun 3, 2004 07:07 PM
RidinLow
Nov 15, 2001 08:56 PM
