Engine Splash Shield?
Old Nov 21, 2015 | 11:06 AM
Carbo's Avatar
9th Gear
We have a 2014 TL. My wife loves to pull all the way into a parking spot until she hits the curb. The result is a crack in what I think is called the Engine Splash Shield?
Can this be safely removed and discarded? Does it need to be replaced? If so, any recommendations on where I can find one? Cost? Thank you.
Old Nov 21, 2015 | 11:33 AM
RedRyder's Avatar
Be a better driver
Most of the time these are attached using the typical Honda plastic clips, which you can pop out with an OEM tool or flathead screwdriver. As for replacing it, not everyone agrees they are essential but personally I've always believed they were there for a reason. So if it were me I would replace it.
you can buy one new from your local dealer or an online dealer, or try to find one used in eBay or a junkyard.
Old Nov 21, 2015 | 11:36 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Here you go. Cheap + free shipping:
Amazon.com: Genuine Acura Parts 74111-TK4-A00 Lower Engine Cover: Automotive Amazon.com: Genuine Acura Parts 74111-TK4-A00 Lower Engine Cover: Automotive
Old Nov 21, 2015 | 12:37 PM
Carbo's Avatar
9th Gear
Thanks for the quick replies. Princelybug, that link you provided isn't working. Typo?
Old Nov 21, 2015 | 01:19 PM
Reorge's Avatar
That part number seems to be incorrect, or at least have been replaced by another part.
According to this OEM parts website the parts are the same for the base & SH-AWD.
Base (item 6): FRONT FENDERS for 2014 Acura TL
SH-AWD (Item 6): FRONT FENDERS for 2014 Acura TL.
I changed mine on an older TL. It's a little frustrating for one person to install because its large but it's doable. Put car on jack stands in the front and take both front wheels off. I HIGHLY recommend replacing all the push-pins (items 17 & 18). Some of them will break when you remove them.
Also, put the part in the sun for a while to warm it up and "soften" it a little. The plastic material is very rigid when it's cool/cold. This makes maneuvering it into place easier.
Old Nov 21, 2015 | 04:46 PM
Carbo's Avatar
9th Gear
Big help, Reorge. Thank you.
Old Nov 21, 2015 | 08:37 PM
Reorge's Avatar
You're very welcome. And ALWAYS blame car damage on the wife.
Old Nov 21, 2015 | 08:45 PM
csmeance's Avatar
pb blaster on the clips makes removal very easy!
Take this as an opportunity to change your Trans fluid and oil if you need to!
1slowcrx
Nov 22, 2015 10:10 PM
bigcocoon
Nov 21, 2015 05:44 AM
nyse_19
Nov 19, 2015 11:04 AM
Tony Sary
Nov 19, 2015 08:31 AM
