need help! wont shift out of park
Old Nov 20, 2015 | 05:34 PM
1slowcrx's Avatar
I need some help! 2000 acura tl, wont shift out of park, but you can put key in hole next to shifter to shift to neutral , start car and put into drive or reverse no problem. drives perfectly fine. just cant shift out of park normally. need ideal where to look or what maybe the cause??? thanks
Old Nov 20, 2015 | 06:04 PM
MarcDavidoff's Avatar
It is likely your the switch located at the brake pedal. It activates the shift interlock solenoid so you can shift. It is pretty simple to change out
Old Nov 22, 2015 | 10:10 PM
01tl4tl's Avatar
start with cking EVERY brake light bulb including the center one in rear window
but the switch may be loose or worn out at pedal, easy DIY
icu2tsx
2G TSX Problems & Fixes
19
Dec 15, 2016 04:26 PM
One of a kind
Texas
Jun 15, 2016 01:29 PM
kev87a
4G TL Problems & Fixes
Nov 13, 2015 08:29 PM
AmitP
5G TLX Problems & Fixes
Nov 6, 2015 08:33 PM
Doom878
Oct 23, 2015 03:30 PM
