The LED are wired to the running lights and the brake lights.
When the running lights turn on the leds turn on but are pretty dim. When the brakes are applied the LED turn brighter. I didn't take enough picture to full show you the process of how to do it. So I pieced together what I could to make this DIY.
After you remove the reflector use a dremel with a cutting wheel to cut the reflector in half like this.
Lay out your led strips how you like it. Keep in mind that you can only cut the strip every 3 leds. Also drill a hole so that you can pass the wire through
Place the reflector cover over the leds and hook it up to a 12v source to test it out and to to see if you like how the leds are laid out.
Add some silicone chalking around the edges. Then clamp the cover onto the back piece. Also chalk around the hole where the wires were passed through.
Next we will have to remove the tail lights
Next we will have to build the the LED controller. Solder it like this
Wire this led controller like this:
The 3 wire harness mention in step above is located on back of tail light
Im deff doing this mod. I had this on my IS350 and got alot of complements on it. However I had mine wired up to my driving lights and turn signals. Would this be possible?
Really a different mod you did there. My issue with small LED lights is I find they look cheap, but I can't say that for sure unless I saw your car on the road. Regardless this is a cool post so thanks for sharing.
Yea, Just wire the line into your turn signals instead of brake but make sure you keep the driving lights on the side with the resistor.
Yea I was a little on the fence about it and thought about using the COB led strip but ended up with the these led strips. They don't looks to bad.
Perfect thank you I plan on doing this mod in the very near future on my 2012. I will post pics for those of you wondering how they would look on a 2012. Im going to try and fit 2 strips of leds in both as I noticed the '12 reflector are smaller in width than the previous years.
Nice. Lmk if you get stuck or something along the way. Maybe you can document your process as well.
