Dlr lights
Old May 30, 2014 | 07:32 PM
ron3.7's Avatar
Dlr lights
Want to replace my stock 9005 daytime running lights with some cool looking lights nothin fancy maybe some LEDS or HIDS. But my question is in my state when they do a State Inspection they usually check to see if the High Beams are working do installing these lights eliminate the high beams????Or do they make leds or hids with dual low or high beam if ya which ones?
Old May 30, 2014 | 11:41 PM
Camaro194's Avatar
LEDs will make your high beams pretty much useless. They will function the same but light output will be much lower. You already have HIDs for headlights. Just turn those on if you want that look instead of the halogen drls.
How did the oil change go?
Old May 31, 2014 | 07:54 PM
ron3.7's Avatar
Hi
Whats up man I changed the oil with mobil 1 advanced synthetic not the extended performance and used a Mobil extended performance filter set oil light to 100% milage was14002 .I will check the oil every 1000 miles or so just out of curiosity and bordem and yes I rotated the tires and put alittle anti seize lubricant on the threads.I changed the air filter and will do the cabin filter tomorrow.Price if you're curious Mobil 1 $25.96, Oil Filter $9.99, Air Filter Wix Free, Cabin Filter Wix Free, Total $35.95.The air and cab filters were free because I work at a car parts distribution warehouse and living in a tax free state helped alittle the oil and oil filter were bought at Walmart . I also changed the oil drain plug got a new one and changed the crush washer also.Next up a nice wax detail.Doing this all myself Piece of Mind.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
